 Post subject: HDD Recovery
PostPosted: November 25th, 2010, 12:20
I have my HDD partitioned for 2 parts C: (System) and D: (Data) and I lost my part D: yesterday. I know there "somewhere" is part D:, but I don´t know where and how I can get it. I tried EASEUS, it has showed me part D: and it still exists but I could not reach and open that.
Please can you give me some advice about it?
Thanks, Jacob
 Post subject: Re: HDD Recovery
PostPosted: November 25th, 2010, 15:57
Try to find an application like R-Studio to open your partition and get data.
By the, what do you mean that you could not reach the partition and open it with Easeus?
PostPosted: November 25th, 2010, 16:42
I have scanned my disc 0 (is C: and D: together) and Easeus has found lost disc D:, it showed me real informations about its, including true size of D:, but I could not get my data from dist D:. But I don´t know why. I´ll try your advice and download R-Studie and I´ll see, what happens.
PostPosted: November 25th, 2010, 17:24
Are you sure that your Easeus is not a trial ?
PostPosted: November 25th, 2010, 17:52
At first it was but then I have downloaded crack full professional version.
PostPosted: November 25th, 2010, 18:03
So it's a bit strange.
Well, try with r-studio and let us know the results.
PostPosted: November 25th, 2010, 18:09
Could we see the partition table and boot sectors with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt.
PostPosted: November 25th, 2010, 18:31
Report file is right here but i don´thing it will help. I´m scanning PC by R-Studio right now and after 10 minutes of process is my progress about 2 percent so I´ll keep it running throw the night and will let you know tomorrow.
Date and time:
źt 25.11.2010
23:23
0001.033
Sector Inspector Copyright Microsoft Corporation 2003
Error 5 was encountered while opening \\.\PHYSICALDRIVE0.
Pístup byl odepen. (access was denied)
Error 5 was encountered while opening \\.\PHYSICALDRIVE1.
PostPosted: November 25th, 2010, 18:41
You may need to give yourself administrator privileges.
If R-Studio doesn't work for you ...
Does the second partition show up in Disk Management?
Can you see it with TestDisk or Partition Find and Mount?
http://www.cgsecurity.org/wiki/TestDisk
http://findandmount.com/
PostPosted: November 25th, 2010, 21:58
You disk your data. But there is a reason why your D partition is gone. If you want to get it back clone your drive. This is the first step you should be doing now instead of running all kinds of recovery program on your orignal drive. Clone it!!!!!!
This is the first thing anybody who gives advise should tell you. Sorry most important to work from a clone on this one. There is a reason behind this one and I am not saying your disk has errors but it is possible. You can lose data on it at anytime if this one is true.
You disk, your data, But any professional who reads this will tell you to stop now, clone your drive, and work from clone. You can always fix your drive later on after you get back your data of the clone.
Best advise to you never work from a drive that has problems even logical problems always work from a clone of this drive. You will have a better chance of getting back your data.
Iorana Haraharaini
Users browsing this forum: No registered users and 167 guests
