 Post subject: Fimware needed 3.AAC - Seagate
PostPosted: April 30th, 2010, 9:31
I need the below firmware for my Seagate 250GB SATA HDD.
Firmware: 3. AAC
Model Number: ST3200310AS
 Post subject: Re: Fimware needed 3.AAC - Seagate
PostPosted: April 30th, 2010, 10:34
IF the drive is 250 GB it CAN'T be ST3200310AS
PostPosted: April 30th, 2010, 10:41
Oops.
The model is ST3250310AS
PostPosted: April 30th, 2010, 11:02
You can find it here:
http://files.hddguru.com/download/PC-30 ... Y26404.rar
Rgds
www.datasave.ro
PostPosted: April 30th, 2010, 11:43
Well the P/N number doesn't match. Here is the complete detail
Product Number: 9EU132-305
Firmware: 3. AAC
Site Code: WU
Product of China
PostPosted: April 30th, 2010, 12:25
If P/N number has to match for you, refer to a data recovery pro to recover data from that drive.
www.datarecoveryne.com
PostPosted: April 30th, 2010, 20:02
i am interesting in why had to match PN :D
data recovery service[/b]
PostPosted: May 1st, 2010, 3:41
BTW Why do you need the firmware for?.....It looks that you don't know much about hdds, so what do you do with firmware files?
Rgds
www.datasave.ro
PostPosted: May 5th, 2010, 2:48
I want the firmware to flash my hard-drive, chances are my hard-drive has got corrupted firmware.
Is there any way to backup the current firmware and write this new firmware, how do i go about doing that ?
Also all this has to be done via bootable diskette.
PostPosted: May 5th, 2010, 3:08
NO! NO! NO!
Your hdd is not a cellphone, you cannot simply "flash" firmware to/from HDD with freeby s/w.
PostPosted: December 28th, 2010, 4:18
Hello guys,
I have the same HDD (ST3250AS fw 3.AAC).
I was able to format track 0 using Seagate SeaTools
but all other "tests" fail
I am also able to create a partition (no errors) but I am not able to format it (error reading sector).
I was also able to run a MHDD scan starting from a certain sector, but even when I change the starting sector
each time the first one is unreadable while the rest are just fine like a new HDD.
It seems to me the HDD firmware is defective.
I would greatly appreciate it if you guys could help me out with this.
What can I do to make this drive work again?
Thank you.
PostPosted: December 28th, 2010, 5:22
Трябва ти специализиран хардуер и софтуер за да можеш да "пипаш" фирмуера на този диск и знания как да го направиш. По добре си похарчи парите за един нов с гаранция.
Иначе "за спорта" може да му пуснеш security erase или erase през MHDD.
DataRecovery.bg
PostPosted: December 28th, 2010, 8:20
Samo wrote:
You need specialized hardware and software so you can "touch" the firmware on this disk and knowledge of how to do it. Better to spend money for a new one with a warranty.
Otherwise, "for sport" you could try security erase or erase in MHDD..
Thank you Samo,
I could try these when I have time. I think I already tried them tough.
Can I sell it to you? If you can use it for something. If yes - my skype is hypnologic
Users browsing this forum: Google [Bot] and 193 guests
