 Post subject: seagate 5400.4 reading defects ?
PostPosted: March 10th, 2013, 16:59
i have this seagate 5400.4 drive .
connected the drive to ddi4 , and when powered on , it takes a long time until it identify and gets ready "~35 secs".
testing the source media " as no head map available for this model " will result in a PASS " all green" but each block will take ~ 45 secs to finish testing .
trying to image the mfts is too too slow , using several imaging passes .
i am thinking it's heads defect . :?
any ideas ?
thank you
 Post subject: Re: seagate 5400.4 reading defects ?
PostPosted: March 10th, 2013, 17:01
sector latency while imaging is ~1050 ms
PostPosted: March 11th, 2013, 4:34
So as a 'pro' why don't you tell us the results of your tests which lead you to this conclusion. Otherwise any opinion expressed by any person here is just a guess!
PostPosted: March 11th, 2013, 13:21
any ideas ?
thank you
the problem seems to be that you are trying to image the disk without properly identifying the problem. If it was heads defect then media would likely spin down. Could be a single failed head or failing head, but it sounds like you have read problems regardless of which head you read.
Terminal output could give a much better idea of the problem, but going straight for recovery without knowing the problem is not good. Assuming the problem is the heads and you pursue an image attempt you could cause irreversible damage. Assuming the problem isnt heads and you change them, this could cause irreversible damage.
Start with terminal, what does it show?
PostPosted: March 12th, 2013, 2:42
thank you all for the feed back .
the drive givving the following :
Rst 08M
Buzz HM SFI
(P)S(H)SAT Er 00 Nwt Er 43 RdWr 045af.02.0000
ATA St 80 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 06bfa189 18 06bfa189.0.0c0 0604 1cb2 2226 0000
CE Log ErrCode=43 LBA=6bfa189 Type=4 Remove from Pending 6bfa189
AT Er 00 Nwt Er 43 RdWr 045af.02.0025
Niwot: 06bfa18a 18 06bfa18a.0.0c0 0603 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0025
CE Log ErrCode=43 LBA=6bfa1ae Type=5 Add To Pending 6bfa1ae
Niwot: 06bfa1af 18 06bfa1af.0.0c0 05de 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0049
CE Log ErrCode=43 LBA=6bfa1d2 Type=5 Add To Pending 6bfa1d2
AT Er 00 Nwt Er 43 RdWr 045af.02.041f
Niwot: 06bfa1d3 18 06bfa1d3.0.0c0 05ba 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.041f
CE Log ErrCode=43 LBA=6bfa5a8 Type=5 Add To Pending 6bfa5a8
AT Er 00 Nwt Er 43 RdWr 045af.02.0439
Niwot: 06bfa5a9 18 06bfa5a9.0.0c0 01e4 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0439
CE Log ErrCode=43 LBA=6bfa5c2 Type=5 Add To Pending 6bfa5c2
AT Er 00 Nwt Er 43 RdWr 045af.02.0440
Niwot: 06bfa5c3 18 06bfa5c3.0.0c0 01ca 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0440
CE Log ErrCode=43 LBA=6bfa5c9 Type=5 Add To Pending 6bfa5c9
AT Er 00 Nwt Er 43 RdWr 045af.02.0443
Niwot: 06bfa5ca 18 06bfa5ca.0.0c0 01c3 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0443
CE Log ErrCode=43 LBA=6bfa5cc Type=5 Add To Pending 6bfa5cc
AT Er 00 Nwt Er 43 RdWr 045af.02.044f
Niwot: 06bfa5cd 18 06bfa5cd.0.0c0 01c0 1cb2 2226 0000
CE Log ErrCode=43 LBA=6bfa5d8 Type=4 Remove from Pending 6bfa5d8
AT Er 00 Nwt Er 43 RdWr 045af.02.045f
Niwot: 06bfa5d9 18 06bfa5d9.0.0c0 01b4 1cb2 2226 0000
CE Log ErrCode=43 LBA=6bfa5e8 Type=4 Remove from Pending 6bfa5e8
AT Er 00 Nwt Er 43 RdWr 045af.02.0463
Niwot: 06bfa5e9 18 06bfa5e9.0.0c0 01a4 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0463
CE Log ErrCode=43 LBA=6bfa5ec Type=5 Add To Pending 6bfa5ec
AT Er 00 Nwt Er 43 RdWr 045af.02.0471
Niwot: 06bfa5ed 18 06bfa5ed.0.0c0 01a0 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0471
CE Log ErrCode=43 LBA=6bfa5fa Type=5 Add To Pending 6bfa5fa
AT Er 00 Nwt Er 43 RdWr 045af.02.0476
Niwot: 06bfa5fb 18 06bfa5fb.0.0c0 0192 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0476
CE Log ErrCode=43 LBA=6bfa5ff Type=5 Add To Pending 6bfa5ff
AT Er 00 Nwt Er 43 RdWr 045af.02.048f
Niwot: 06bfa600 18 06bfa600.0.0c0 018d 1cb2 2226 0000
CE Log ErrCode=43 LBA=6bfa618 Type=4 Remove from Pending 6bfa618
AT Er 00 Nwt Er 43 RdWr 045af.02.0491
Niwot: 06bfa619 18 06bfa619.0.0c0 0174 1cb2 2226 0000
CE Log ErrCode=43 LBA=6bfa61a Type=4 Remove from Pending 6bfa61a
AT Er 00 Nwt Er 43 RdWr 045af.02.0497
Niwot: 06bfa61b 18 06bfa61b.0.0c0 0172 1cb2 2226 0000
DiskAccess ReadSector EC=43 at 0046a1.02.0497
CE Log ErrCode=43 LBA=6bfa620 Type=5 Add To Pending 6bfa620
AT Er 00 Nwt Er 43 RdWr 045af.02.04a3
Niwot: 06bfa621 18 06bfa621.0.0c0 016c 1cb2 2226 0000
PostPosted: March 12th, 2013, 4:15
This is pending problem, a firmware issue. Far from head related like you suggested which stresses the importance of a good diagnostic.
You can solve easiest with PC3000 and using Loader. Other option is to rewrite table with a specific terminal command but this can potentially make things worse also.
Do you have PC3000 for this?
PostPosted: March 12th, 2013, 4:19
thank you very much for the hints .
meanwhile , i donut have pc-3000 , but looking to . "been in contact with ace labs "
i am looking to solve this issue with the ordinary terminal .
