 Post subject: HITACHI HDT721050SLA360 is spinning but HSA doesn't move
PostPosted: March 17th, 2013, 13:53
Hello to all,
Just like mentioned in the subject of the post my HITACHI HDT721050SLA360 is spinning but I can't hear the sound of HSA.
I am not sure but I suppose that maybe it's not full spin that's why HSA is not ready to move over the platters.
Is there a possibility to connect this drive to COM terminal or check the current RPM of drive in any possible way?
I checked PCB (measuring voltages) according to the post:
hitachi-hdt721010sla360-not-spinning-tvss-t21878.html
I am thinking about buying and replacing PCB.
Any more ideas?
File comment: Voltage input: 5,07V; 11,90V
Q2 (from left) 3,26V; 5,04V; 3,90V
L1 -4,95V
L3 5,07V
L300 1,08V
L310 2,50V
DC Motor 5,91V for each
 Post subject: Re: HITACHI HDT721050SLA360 is spinning but HSA doesn't move
PostPosted: March 17th, 2013, 13:57
Sometimes this is a symptom of bad heads with media damage.
http://www.datasaversllc.com
PostPosted: March 17th, 2013, 14:04
Agreed. See this often.
PostPosted: March 17th, 2013, 14:58
3rd this one
Iorana Haraharaini
PostPosted: April 15th, 2013, 6:36
Problem solved,
PCB and ROM replaced.
PostPosted: April 15th, 2013, 9:42
Well done, nice result.
PostPosted: April 15th, 2013, 10:17
That's a very curious fault. :?
Do you still have the original PCB?
PostPosted: April 20th, 2013, 8:33
I don't have original PCB right now, but I could if it is important.
Some idea?
PostPosted: April 23rd, 2013, 18:45
Could it have been as simple as a dry solder joint at the NVRAM?
If the drive wasn't able to get up to speed, wouldn't it eventually have spun down?
Users browsing this forum: WebClaw and 26 guests
