 Post subject: I need help from a PCB expert | Does this revision matter?
PostPosted: September 4th, 2013, 12:10
Right I have a wd hard drive it failed on me.
I have two of the same hard drive
Failed hdd pcb no. is: 2060-771761-001 REV P1
2nd identical hdd pcb is: 2060-771761-001 REV A
Would the Revision code make a difference? Everything looks identical including the chip numbers etc
Say if i was to swap the 2nd pcb onto the first hdd, would it work?
 Post subject: Re: I need help from a PCB expert | Does this revision matte
PostPosted: September 4th, 2013, 13:00
Anyone?
PostPosted: September 4th, 2013, 14:42
Rev should be ok, just swapping likely not ok.
Users browsing this forum: Google [Bot] and 72 guests
