 Post subject: Rom chip
PostPosted: May 28th, 2013, 5:48
ST3250318AS
Barracuda 7200.12
250 GB
PLEASE guide me where is the (ROM CHIP)on this pcb
 Post subject: Re: Rom chip
PostPosted: May 28th, 2013, 5:56
Top left corner chip.
Should be written on it 25P40 or 25X40 or something similar
My firmware database:
PostPosted: May 28th, 2013, 6:24
http://www.users.on.net/~fzabkar/HDD/HD ... Flash.html
http://www.users.on.net/~fzabkar/HDD/HD ... _Regs.html
PostPosted: May 28th, 2013, 7:33
when i replace the patient's pcb with donor pcb, i also replace the ROM chip of patient pcb the power goes off. hdd has no detection
PostPosted: May 28th, 2013, 7:35
What are the original symptoms with the original pcb?
Why do you think that your pcb is faulty?
PostPosted: May 28th, 2013, 8:05
PATIENT PCB has no power , it is already dead.
when i replace a patient dead pcb
with donor ok pcb,the hdd power is on,but has no detection.
I replace ROM chip off ok pcb with dead pcb power goes off.
PostPosted: May 28th, 2013, 8:26
Then you have a shortcircuit in ROM
http://www.rescue-it.se
PostPosted: May 28th, 2013, 8:42
i think need a firmware reset with terminal mode :D
PostPosted: May 28th, 2013, 8:53
Measure the resistance between pin #4 and pin #8 of the flash chip.
Is your photo showing the damaged board or the donor?
PostPosted: May 28th, 2013, 9:33
please Mr fzabkar
see these both pictures of patient & donor pcb & guide me
PostPosted: May 28th, 2013, 15:31
See attachment.
PostPosted: May 29th, 2013, 4:32
+1
That can be caused by poor soldering too.
PostPosted: May 29th, 2013, 4:39
northwind wrote:
+1
Will help using a bit of flux or higher soldering temperature and higher air pressure.
With my soldering station i do it usually at 300° C
PostPosted: May 29th, 2013, 5:35
Mr northwind
see the picture.i have sold the Rom chip accurately.
but the problem remain same
PostPosted: May 29th, 2013, 9:47
I'm not sure pin #4 (which by the way involves itself into the power supply) is making good contact.
PostPosted: May 29th, 2013, 12:21
Wrong chip ...
NTMSD3P102R2, ON Semiconductor, marking E3P102, FETKY P–Channel Enhancement–Mode Power MOSFET & Schottky Diode, Dual SO–8, –3A, –20V, 0.085 ohms:
http://www.onsemi.com/pub/Collateral/NTMSD3P102R2-D.PDF
http://www.datasheetcatalog.org/datashe ... 02R2-D.PDF
PostPosted: September 18th, 2013, 17:31
100% true
Users browsing this forum: Bing [Bot], Google [Bot] and 46 guests
