 Post subject: 7200.12 serial terminal - can't ctrl-Z
PostPosted: October 10th, 2013, 6:19
I'm sure I've read about this before, but cant find the topic
probably under 7200.xx LED issues
I have a couple of working 7200.12's
500GB
can ctrl-Z and get in ok most of the time)
(although sometimes depends if the sata data cable is also connected or not)
1TB
see the Rst 0x20M at power on
but cant get in with ctrl-Z
even if wait a bit
Do you need to do anything special to get in with ctrl-Z
eg shorting the read channel
 Post subject: Re: 7200.12 serial terminal - can't ctrl-Z
PostPosted: October 10th, 2013, 6:27
Yep, a tweezer Wight be handy :mrgreen:
http://www.rescue-it.se
PostPosted: October 10th, 2013, 6:31
Probably need
viewtopic.php?f=1&t=18907&p=180670&hilit=+7200.12+led#p180670
[Power your hdd with shorting read channels as R0b and bochen415 says like in that image: http://qbhn.neostrada.pl/02.jpg]
PostPosted: October 10th, 2013, 13:21
For info
The half height 1TB has the board shown at http://qbhn.neostrada.pl/02.jpg
ST31000528AS
Firmware: CC38
The third height 500GB has a smaller, rectangular, board
ST3500418AS
Firmware: HP35
