 Post subject: Seagate 7200.7 - unsual spin up & down
PostPosted: April 30th, 2010, 13:57
Drive spins up, clicks a little and spins down. Unusual for a seagate. On one occasion I was able to access the SA, read the modules, except APP which could not be read. However all of the other times the drive spins down after a few seconds. If I crtl + z then the drive stays busy and will not spin down or click.
Does any one have a clue for this one? I don't think it is just the CE log error?
Pasted command console below:
Interface task reset
4096k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 0000 - Switch to full int.
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
Best wishes,
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
 Post subject: Re: Seagate 7200.7 - unsual spin up & down
PostPosted: April 30th, 2010, 15:44
Open it , and look the plattes.
ZeBong
" Россия еще раз"
PostPosted: May 1st, 2010, 14:15
No obvious damage to the top platter, from what I can see of the rest they look good.
John
PostPosted: May 2nd, 2010, 5:34
You have bad heads , if drive is above 40gb then :
F>j,,1
T>Y20
ctrl+T
PostPosted: May 4th, 2010, 4:40
Drive is ST3120026A / Alpine (U9).
On the one attempt the drive got to SA I have modules 1 through 10 except number 7 (APP).
I wasn't sure if the (P)PATA Reset suggested that the heads were OK?
Log output:
Buzz - (
F>Head Mask 0000 - Switch to full int.
Spin Ready
F>j,,1
8.01 04-05-04 15:38
T>Y20
T>(Interface task reset
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Stuff Was Unreadable(
T>
Best wishes,
John
PostPosted: May 14th, 2010, 10:39
I fixed the 'stuff' error. Now I get the following in the cmd. I think it's fairly safe to assume now that it is the heads?
Head Mask 0008 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0004 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0004 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0002 - Head Mask 0004 - Head Mask 0000 - Head Mask 0000 - Head Mask 0004 - Head Mask 0002 - Head Mask 0004 - Head Mask 0008 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0001 - Head Mask 0000 - Head Mask 0004 - Head Mask 0000 - Head Mask 0000 - Head Mask 0003 - Head Mask 0002 - Error Reading Reserve Track Defect List
F>
PostPosted: May 14th, 2010, 10:42
I would assume so.
PostPosted: May 14th, 2010, 11:38
Oh yeah. Check heads.
PostPosted: May 14th, 2010, 16:39
send it to a pro!
PostPosted: May 14th, 2010, 17:49
guru wrote:
send it to a pro!
Thats what I was thinking. :lol:
Doctor Reid, send it to a hard drive Doctor.
PostPosted: May 15th, 2010, 16:34
From website "We estimate that we can recover data in 90% of cases" oh dear this must be part of the 10% ?
PostPosted: May 21st, 2010, 20:29
Now-now; head issue all resolved now, all the data recovered.
PostPosted: May 22nd, 2010, 4:31
you would say that. :roll:
PostPosted: May 22nd, 2010, 4:51
No, I just have an associate whom deals with this kind of failure very well. I am aware of my own abilities and where they start and where they end. That is what keeps the recovery rate high rather than taking a cavalier approach and attempting procedures that would risk a customer's data. Whatever you might think I do aim to be responsible when conducting my work.
All the best,
John
PostPosted: May 22nd, 2010, 8:25
sorry my mistake, given your credentials, experience and your website, I was under the impression you could deal with this yourself.
PostPosted: May 22nd, 2010, 14:45
I would love to develop my data recovery skills further, and after a recent move I am in a better position to install facilities to take things on. However, the big dependent factor, as I am sure it is for many for us, is time. My work load is roughly split 50% data recovery, 25% ICT support for companies whose servers/RAID arrays I have recovered. Moreover, as my appellation might suggest I am also an active researcher having to deal with gaining publications which makes up the remainder of my working time. Trying to find a balance is tough. Leisure time, what's that?! :)
If of course you are willing to offer training to me at reasonable rates, well I would be more than happy to accept. I don't pretend to know everything, that's why I ask questions here sometimes, I just keep trying to learn a little bit more each time.
PostPosted: May 22nd, 2010, 15:13
at least your honest bravo!
PostPosted: August 2nd, 2014, 7:48
I have one , and can try to help if you need to compare my logs (need SA offsets) ..
Please (free) help :
http://rzr.online.fr/q/hdd#
how to unlock/format ST3120026A in max security ?
"ALPINE - 1_Disk M.14 01-16-03 11:51"
Users browsing this forum: No registered users and 42 guests
