Good morning friends ,,
i have this drive from a client , and it's encrypted using bitlocker .
drive has a weak head , and i could image it to another 1 TB drive successfully , except some LBAs that belongs to the weak head .
after i finished with the good heads , i tried to retry the failed blocked of the weak head , but drive is hanged now on BSY state ...
firing WDII- DFL and try to further diagonise the issue , i got the same result
first drive acting normally , DSC and DRDY , but once i request any thng , the BSY led with light up and nothing can be read off the drive again ,,
tried to fix the bitlocker on the partial image drive , and failed , appearantly the weak head holds critical data for the encryption ..
any help to squeeze more data of the drive ? thanks in advance
| Attachments: |
