 Post subject: Seagate 2tb HDD pcb got fired
PostPosted: September 26th, 2012, 22:50
Dear all,
i have accidentally fired my 2TB seagate barracuda hard disk pcb.I have another pcb of Barracuda same pcb number, firm ware, model but the revision is different.
100617465 REV A and fired pcb is 100617465 REV B.
My doubt is whether i can swap the pcb to recover the data.
if i can swap then Should i swap the rom also from fired pcb to the other
please help
 Post subject: Re: Seagate 2tb HDD pcb got fired
PostPosted: September 27th, 2012, 1:52
Hi, yes you need to swap Rom as well.
http://www.rescue-it.se
PostPosted: September 27th, 2012, 5:39
hi mr_spokk,
thanks for your reply..What does the REV A and REV B stands for
PostPosted: September 27th, 2012, 10:59
Won't matter. PCB's are compatible.
PostPosted: September 27th, 2012, 22:57
Dear Northwind,
Thank you very much for your reply.
the pcb was actually one from Barracuda green and another from barracuda Lp where model number, firm ware and pcb number are same except for the rev a and rev b and also the site code.
site code and rev was different in both the hard disks.
lot of thanks
PostPosted: September 28th, 2012, 3:43
Hi
Just try it.
It should work.
PS. If you dont feel comfortable about soldering, have someone skilled to do this for you. ROM's for seagates are unique, if you mess this up, bye-bye data (well, almost).
You also accept the risks of DIY blah blah blah..
PostPosted: October 8th, 2012, 14:43
Dear all,
I have swapped the rom. for that purpose i purchased a cheap smd rework station and have sucessfully swapped the rom. now iam in the process of backing up the data.
thank you for all who guided me in this mission
rahul vc
PostPosted: October 8th, 2012, 16:31
You're welcome.
PostPosted: October 9th, 2012, 2:26
Good job.
PostPosted: October 9th, 2012, 3:15
Well done!
DIY has its place, and this is a good example of success.
But this doesn't make every case so. :-)
PostPosted: October 9th, 2012, 8:29
vcrahul wrote:
Dear all,
rahul vc
Even the simple DIY requires some technical ability and investment. No way around it...
PostPosted: November 4th, 2014, 8:17
Dear all,
I got an identical pcb for the fired hdd from data pro data recovery Canada. I have send the burnt pcb to them and they have given me a pcb which is cloned. I installed the hdd and found that it's detecting but the size was showing only 8gb instead of 2tb. Could anyone throw light into this?.
Users browsing this forum: Majestic-12 [Bot] and 59 guests
