 Post subject: ST3000DM001 firmware failure or not?
PostPosted: December 27th, 2014, 10:04
Hi guys,
this forum is awesome, but I haven't been able to find the information I was looking for.
I have a Seagate ST3000DM001 3TB HDD which is not recognized any more.
When I attach power to the drive, it spins up and sounds normally - heads moving after spin-up, but no clicking sounds.
The serial port gives me:
Boot 0x40M
Spin Up
Trans.
Spin Up
(P) SATA Reset
I wanted to try ctrl+z, but no response.
I disconnected the heads with some plastic between the connectors and the PCB, then the following happens:
*device spins up
Boot 0x40M
Spin Up
FAIL  Servo Op=0100 Resp=0003
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1C00 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 D8AD EAFE 9101 1A06 65FC FB6D 37BF 1B6F 5F17 B9E7 0000 007F 0004 0000 FFF7 0004 0010
ResponseFrame 2200 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 D8AD EAFE 9101 1A06 65FC FB6D 37BF 1B6F 5F17 B9E7 0000 007F 0004 0000 FFF7 0004 0000
*motor spins down again
Of course I searched the forum and the internet, but the only similay post was this one http://forum.hddguru.com/viewtopic.php?t=22217&f=1&start=0#p187190 with another drive and not exactly the same output. I hope anybody could help me diagnose my hdd.
Thanks in advance and best regards,
termi
 Post subject: Re: ST3000DM001 firmware failure or not?
PostPosted: December 27th, 2014, 19:34
Most probably, Bad PCB, bad Heads.
PostPosted: December 27th, 2014, 22:44
Most probably, bad firmware.
http://www.datasaversllc.com
PostPosted: December 28th, 2014, 11:58
okay - can I try anything else to identify the problem?
@jono-ats: Would a new pcb solve this problem if it was the firmware or can I try anything else myself?
@pikus_09: Wouldn't I always get a FAIL message if it were the heads?
PostPosted: December 28th, 2014, 13:12
I don't think it's a PCB problem, so a replacement won't make any difference.
Sometimes this type of problem is a challenge for pros; I don't think it's very feasible for you to fix it yourself without the proper tools and lots of experience.
PostPosted: December 29th, 2014, 12:55
yes, but head can not find information on the servo, it is not the fault of the PCB, because if it was not started to drive. I checked on her a patient in.
PostPosted: December 29th, 2014, 13:03
I'm with Jono on this one. I haven't seen many DM drives with PCB issues, it's usually either bad heads or bad sectors in the SA (firmware). Might be fixable, but these drives are a nightmare even for professionals. Not likely a DIY case. I'd send it out to someone with more experience on these.
PostPosted: December 29th, 2014, 14:07
PostPosted: December 29th, 2014, 14:08
Strange how that message posted twice. :?: :?: :?:
PostPosted: December 31st, 2014, 9:52
Agree with Jon, not PCB and it's not spinning down or clicking when powered up normally so heads are probably fine. Issue with firmware area most likely, not a DIY job.
Data Recovery Cape Town
PostPosted: January 8th, 2015, 15:53
Thank you all for your input. I will give it to a pro in town.
PostPosted: January 8th, 2015, 15:59
Just out of curiosity - what exactly is called 'servo' in hdd terms?
Isn't it the motor which drives the heads? Like servos in RC cars or any other machines...?
Somehow I got the feeling you were talking of something else :D
Users browsing this forum: Google [Bot] and 80 guests
