 Post subject: WD2500BMVS
PostPosted: June 9th, 2015, 3:52
I receive drive for datarecovery.
First drive not start at all. Then I clean all contacts. After that, drive start producing sounds like sirene( 5 times) and stop.
Drive is detected as Venus family, without model and size.
 Post subject: Re: WD2500BMVS
PostPosted: June 9th, 2015, 4:46
Is that a client's drive?
PostPosted: June 9th, 2015, 4:57
yes it's client drive
wd.zip [155.98 KiB]
Downloaded 294 times
PostPosted: June 9th, 2015, 5:47
Are you take a look inside case?
PostPosted: June 10th, 2015, 1:22
Techno mode key
Techno mode key......................... : Ok
Debug Stop Code......................... : DEBUGSTOP CRT RAISE
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 128
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 08.8WA
ROM F/W version......................... : 0008008W
Overlay F/W version..................... : 08.8WA
Servo F/W version....................... : 01.91
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Read ROM
Into file............................... : <HDD Profile>\Data\ROM\ROM_0008008W.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
Module : 0D............................. : Ok
Module : 4F............................. : Ok
PostPosted: June 10th, 2015, 2:53
Physical issue I would imagine.
Heads damaged/bad/stuck/mangled I would guess.
Either way, not DIY :-(
PostPosted: June 10th, 2015, 9:22
Problem with head (s).
PostPosted: June 10th, 2015, 10:03
I ask because i think the same as pcimage
