 Post subject: Seagate : rebuild
PostPosted: June 9th, 2015, 9:13
hello
I have an seagate Momentus 7200.4 (ST9250410AS) 250Go and i can't use it because is smart tripped.
I not need this hdd, I want use to understand how it's work.
I open a stcom terminal
I sent /N1
and
"m0,2,2,0,0,0,0,22"
for me , N1 clear the smart data
and m0 'pre-format' the hdd (define ok or bad sector)
but of course if I post here.. that doesn't work
The smart is not more tripped
but the pre-format not seen to have work
What I need to do to totally 'rebuild' this disk ?
(i don't want to use it, just clear it, use it for test and see it become tripped after some time)
thanks
 Post subject: Re: Seagate : rebuild
PostPosted: June 9th, 2015, 13:39
Throw it away and buy a Toshiba or HGST :D
If you want to learn more about the M command in terminal you should start here: https://www.data-medics.com/forum/viewt ... f=26&t=100
PostPosted: June 10th, 2015, 2:26
m0 command is only valid for extract data, not for use the drive commonly
PostPosted: June 10th, 2015, 4:01
Hello
thanks for your answer and the document.
This is my log :
Rst 0x10M
(P) SATA Reset
ASCII Diag mode
F3 T>i4,1,22
F3 T>m0,8,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
and after one hour I have only :
LED:000000CE FAddr:0029D7F3
and I DON'T have something like this :
"User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 10 mins 00 secs "
since error seem to b always in the same address "0029D7F3"
can I modify number of retry in the m0 command line ?
If i modify only [MaxWrRetryCnt],[MaxRdRetryCnt] from 0 to 5 (for exemple) it could be good solution ?
thanks
PostPosted: June 11th, 2015, 0:10
Banned User
REBUILD ALL :
F3 T>m0,2,1,,,,,22
F3 T>m0,2,2,,,,,22
F3 T>m0,2,3,,,,,22
your hdd can bad full , can't repair, i not repair seagate f3, build ----> repair----> error
PostPosted: June 15th, 2015, 4:08
RIP
