Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Recover From My Book Duo
PostPosted: September 28th, 2016, 14:07
Reading this thread, I can't help but get the sense that we are missing some major detail here.
PostPosted: September 28th, 2016, 19:25
WD My Book Duo hardware encryption:
http://forum.acelaboratory.com/viewtopic.php?t=8848&p=30771#p30771
AES-256 hardware encryption key should be in original NAS board only. So, to decrypt the data you need to use the original key from native NAS.
Another twist ...
http://forum.acelaboratory.com/viewtopi ... 214#p31214
The 6TB [MyBook Duo] is the one with the dead enclosure which did not have a user password and doesn't have a key on the drive.
The 4TB [MyBook Duo] has the working enclosure and according to the client had a user password. Both drives are working and both have encryption keys on them.
PostPosted: September 29th, 2016, 5:00
Roberto wrote:
Can you please show us the label of the HDDs from my book duo?
attached.
File comment: mybook duo
File comment: hard disk
PostPosted: October 1st, 2016, 14:19
maxisvk wrote:
It's original configured in RAID1 but for a mistake i force reconfigure it (again to RAID1) from WD Utility.
Can you please tell me the exact date of the mistakenly reconfiguration?
PostPosted: October 3rd, 2016, 11:26
sorry but i don't know exactly, about 2 week ago, why ?
PostPosted: October 3rd, 2016, 16:00
This info helps me a lot in checking your encryption system.
PostPosted: October 4th, 2016, 11:34
The My Book Duo operates using a version of Linux. You might try enabling ssh access then connect to it and see if the data on the disks still looks encrypted or not.
On-Line Data Recovery Consultant. RAID / NAS / Linux Specialist.
Serving clients worldwide since 2011
FreeDataRecovery.us
PostPosted: October 5th, 2016, 6:47
ok, maybe i found it, local time: 9 september at 8:00 am ( UTC + 1 )
PostPosted: October 7th, 2016, 13:16
Thank you for the info... but I have no good news to you....
It seems that your My Book Duo constellation does not use the JMicron encryption chip.
Or maybe it uses a somehow changed version... I don't know.
But I think it's more likely that there is some of the other systems in use, maybe from Initio, PLX or Symwave.
If I'm right.... I cannot help you at the moment... because till now I have only implemented the JMicron system in my software solution.
You could wait till I have the other systems implemented...maybe we could give it another try then.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 84 guests
