 Post subject: Seagate ST3250318AS with LED:000000CD error ?
PostPosted: December 6th, 2016, 6:54
I have Seagate ST3250318AS it stuck on BSY
the terminal keeps giving me this over and over:
LED:000000CD FAddr:00258A17
I replaced head and still the same issue ??
HDD label attached
 Post subject: Re: Seagate ST3250318AS with LED:000000CD error ?
PostPosted: December 6th, 2016, 7:28
May be eeprom fail
pls check eeprom with other same working board
I have same problem
PostPosted: December 6th, 2016, 11:23
prasadsv wrote:
May be eeprom fail
I have same problem
Now i got the SN and model but the size is empty
when i do anything the drive freeze with BSY DRD DSC
PostPosted: December 6th, 2016, 13:12
Have you tried F3 commands in terminal?
http://www.hddoracle.com/viewtopic.php?f=83&t=38 try this with TTL adptor
PostPosted: December 6th, 2016, 14:47
This is a great way to brick the drive and make it unrecoverable. Seriously, read the GIANT RED TEXT THAT SAYS:
DON'T DO IT ON NEWER DRIVES, LIKE 7200.12 OR YOU WILL END UP HAVING FURTHER COMPLICATIONS DUE TO NRG LIST / TRANSLATOR !!!!!
PostPosted: December 7th, 2016, 5:43
head was damaged but after replaced head this happed
it clicks several times then comes to ready
after running utilities i can read model and SN good but firmware showing CC44 which is the firmware of the donor drive and the size is MB ()
when i try to do anything it stuck on BSY DRD DSC.
I have terminal access while it is ready
i am using pc3k
here is log:
Family ID by HDD ID: 3F
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST3250318AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Drive not ready
Terminal : error detecting HDD terminal baud rate
Terminal:
Rst 0x08M
ASCII Diag mode
F3 T>
Rst 0x08M
and this is log when I try to clear SMART:
Executing user command.................. : Clear SMART
ASCII Diag mode
F3 T>/1
F3 1>N1
HighPowerMode
Terminal : reply timeout error
Executing user command.................. : Show Alt-List
LED:000000CC FAddr:002851C7
