 Post subject: I hate Hitachi :( HTS54060G9SA00
PostPosted: December 16th, 2016, 12:13
Friends !
when ever it comes to Hitachi drive i feel depressed even before i start troiubleshoot the issue !
i have this HTS54060G9SA00 , which is not spinning .. initial diagnostics of PCB shows nothing unusual , client claims that drive was used in old laptop , never dropped , never anyhting ..
luckly i have an identical donor , but it doesnt spin as well , and its PCB shows nothing important to notice at all ..
i tested the fuse , its OK
please be kind enough to take a look at the PCB and point me in case you have experience with this model ..
thanks in advance
 Post subject: Re: I hate Hitachi :( HTS54060G9SA00
PostPosted: December 16th, 2016, 13:38
If you need good pcb, I can send you one.
PostPosted: December 16th, 2016, 17:10
You might have better luck finding a donor if you were to search for the correct model number.
PostPosted: December 17th, 2016, 5:20
thanks for the reply , both of you ..
finsing a donor is not a big deal , what bothors me , is that both PCBs have the same issue , and i cant troubleshoot any of them ..
PostPosted: December 17th, 2016, 12:49
Have you put the patient PCB into the donor HDA to see if it spins?
Maybe a bad motor.
You don't ear any sound?
ACELab partner
PostPosted: December 17th, 2016, 13:11
In HITACHI a damaged/corrupted NVRAM will cause the disk to not spin at all.
PostPosted: December 17th, 2016, 14:28
The photo is unclear, but I would measure these points:
Here is a better photo:
https://hddsdatarecovery.com/1370-thickbox_default/hitachi-hts541060g9sa00-pn-0a27403-pcb-320-0a25182-01-.jpg
AFAICT, this is the transistor:
US6T7, Rohm, PNP BJT, GP, 30V, 1.5A, marking T07, TUMT6 package, 6-pin:
http://web.archive.org/web/20150512120237/http://rohmfs.rohm.com/en/products/databook/datasheet/discrete/transistor/bipolar/us6t7.pdf
http://www.datasheetarchive.com/dlmain/5d56517198e97055f20673ff7fc4b7b7491920/M/US6T7
PostPosted: December 17th, 2016, 17:37
The attachment Vcore.jpg is no longer available
The attachment TVS_fuse.jpg is no longer available
The attachment Q401.jpg is no longer available
The attachment F3.jpg is no longer available
appreciate your kind support in this matter ..
please find below the requested measures ..
PostPosted: December 17th, 2016, 18:33
It appears that the DC-DC converter which I assumed was the Vcore supply is in fact a +3.3V Vio supply. Therefore I now suspect that Q401 is the +1.5V Vcore pass transistor. The other +1.5V linear regulator could be involved with the preamp.
In short, ISTM that the 3 supply voltages are probably OK.
If you could upload the NVRAM contents, I could verify the checksum for you.
K4S641632H-UC60, Samsung, 64Mbit SDRAM, 3.3V:
http://datasheet.iiic.cc/datasheets-0/s ... H-UC60.pdf
BR93L66RF-WE2, Rohm, Microwire BUS Serial EEPROM, 256+16bits, marking RL66, SOP8, 1.8V-5.5V:
http://web.archive.org/web/201003070518 ... r93l-e.pdf
http://web.archive.org/web/200603220550 ... 76-w-e.pdf
LE25FV055T, 512Kbit, 64Kx8, Sanyo, Serial flash memory, 8-pin:
http://www.datasheetarchive.com/dl/3441 ... LE25FV055T
PostPosted: December 17th, 2016, 19:24
Could it be a Power Up In Standby (PUIS) issue?
PostPosted: December 20th, 2016, 15:15
this is what makes sense .. PCB is ok , as both PCBs are giving normal reads .. i couldnt manage to dump the flash , as its pretty (strange ) one , and neither my programmer nor my friend's support it ..
i will manage to look up the ROM and flush to a new flash and entirely replace the current one
just out of curiosity , do you have the rom ? :D
thanks
PostPosted: December 20th, 2016, 15:56
This article states that each NVRAM is unique to a particular drive:
Hitachi data recovery tips you must know:
http://www.disk-imager.com/data-recovery-blog/?p=1363
http://www.datarecoverytools.co.uk/wp-c ... ure-01.jpg
http://www.datarecoverytools.co.uk/wp-c ... ure-02.jpg
Furthermore, the NVRAM version needs to match the ROM.
PostPosted: December 20th, 2016, 21:39
raven4d wrote:
Friends !
thanks in advance
Hello ,
Is this model correct .Can you double check if you have really given us the proper model no ,Can you show me the top label picture
PostPosted: December 21st, 2016, 2:57
Amarbir[CDR-Labs] wrote:
raven4d wrote:
Friends !
thanks in advance
Hello ,
sorry ,its HTS541060G9SA00
PostPosted: December 22nd, 2016, 2:43
if its a PUIS issue , am afraid i cant handle it .. i dont have proper tools ..
also , i tried another PCB from a trashed HDD , diffirent model number but it fits on the patient .. and the patient spins OK !!
so its either PUIS or corrupted rom
PostPosted: December 22nd, 2016, 2:54
PUIS can be disabled with HDAT2 (freeware). You need to launch HDAT2 with the /W switch to wake up the drive.
    HDAT2 /W
Users browsing this forum: No registered users and 52 guests
