Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: How to recover WD Mybook Harddisk
PostPosted: September 13th, 2019, 4:27
V1 is low. This voltage should be the +3.3V supply for the ROM and the Vio supply for the bridge. The Vcore supply (V2) is then derived from V1.
Either there is a problem with the ROM or bridge IC, or the 5-pin regulator is faulty. If the ROM's supply voltage really was at 11V on the original PCB, then I expect that the ROM would be dead.
PostPosted: September 13th, 2019, 4:52
OK, is there any possibility to decode the encryption by software?
PostPosted: September 13th, 2019, 15:36
reallymine: WD MyBook/MyPassport decryption :
http://www.hddoracle.com/viewtopic.php?f=22&t=1488
PostPosted: September 24th, 2019, 0:28
its so hard to install it on linux. i can clone it from github but it wont install.
I dont like github its more complicated than precompiled software. Coz theres not really a helpful installationhelp.
It wont work on DDRescue, SystemRescueCD, PartedMagic and Ubunty. Which one do u use? The Precompiled version i found in ur post didnt start. It ask my everytime "how to open"
PostPosted: September 24th, 2019, 4:14
I recommend getting an install of a more complete and versatile Linux distro for this, as the ones you mention are very specialized. Linux Mint is great if you want something lightweight without any unnecesary add-ons. After installing the OS, you should install Go. Then, installing it should be very easy with the command mentioned in the Github README.
$ go get github.com/andlabs/reallymine
Will recover data for food
PostPosted: September 24th, 2019, 5:31
This is what i did, after I installed go.
but if I run the command reallymine i get the result -> unknown command.
Ill post a Screenshot later. ATM another DR is running on this machine.
best regards
Fabian
PostPosted: September 24th, 2019, 7:12
It seems that the package isn’t up to date anymore
PostPosted: September 24th, 2019, 16:38
I have never needed to use reallymine, so I can't help you. There is an alternative software solution written by forum user "Roberto", but it's not freeware.
PostPosted: September 24th, 2019, 21:29
do you have an SA backup ?
is the decryption key there ?
PostPosted: September 25th, 2019, 3:21
If the Price is acceptable and the Software will work than i'm ready to pay for it.
No. How to do?
PostPosted: September 25th, 2019, 4:03
https://forum.hddguru.com/viewtopic.php?t=35048
https://forum.hddguru.com/memberlist.php?mode=viewprofile&u=31982
PostPosted: October 1st, 2019, 0:19
Hi there,
yesterday i recovered the Data with the Linux Mybook Tools from Themaddoctor.
In Linux HDD Sata -> USB 3 target with a transferrate of 53 MB/s.
Its a Linux workflow. At some parts on it its tricky to handle but it works. On my installation 2 tools (explained in the documentation) missed in the linux repository but i could handle it with the standard installation of Linux.
Very good documentation und great help from the developer.
https://github.com/themaddoctor/linux-mybook-tools
Reallymine didnt worked at me Linux. I dont know why. The installation of the tool failed due to missing some installation packages.
Best regards
Fabian
PostPosted: May 16th, 2020, 19:13
It seems that the following voltage is output from a normal operating PCB.
V1=2.5-2.8v
V2=1.0-1.2V
If it's my broken PCB, the place that should be 5v of U3 is 0v.
Users browsing this forum: No registered users and 213 guests
