 Post subject: Change mechanical parts DIY-best way?
PostPosted: February 2nd, 2021, 18:28
Hi!
I'm slowly moving to datarecovery job.
It's not a real business but a nice income beside my full time job.
To this moment I did data recovery without opening the HDD and changing parts,
except electronic repairing etc.
But now I'm really curious how to change mechanical parts in a home environment.
I mean, what type of air cleaning stuff you use where you open the hdd?
I don't think it is a good idea to open a hdd just for replace the head unit for transfering the data
to another hdd in a average room.
Or?
Let's say I have a hdd with a bad mechanical arm, but the discs are ok.
I have to change that arm inside from a donor hdd just for transfering the data to a new hdd.
Is it worth to open in in my service room just in open air?
Thanks for any help and advice.
My best regards.
 Post subject: Re: Change mechanical parts DIY-best way?
PostPosted: February 2nd, 2021, 19:03
If you are working with your own drives, do whatever you want. If you are charging your client to recover their important data, it is best to send it out to a pro.
PostPosted: February 2nd, 2021, 22:04
Do NOT open in a regular room air environment.
You will need a class 100 laminar flow bench or make your own that is up to spec.
https://www.ebay.com/sch/i.html?_from=R ... flow+bnech
https://forum.hddguru.com/viewtopic.php?t=29602
Users browsing this forum: No registered users and 60 guests
