 Post subject: MQ01UBDxx0 TOSHIBA 2,5" USB terminal pinout wanted (if any)
PostPosted: January 26th, 2017, 7:58
Hello to all the community!
do any of you have the pinout to connect the COM/terminal to the TOSHIBA MQ 2,5" USB boards?
If yes, can you kindly share it?
The goal is to read the ROM through terminal on TOSHIBA USB boards
thank you
Cor
 Post subject: Re: MQ01UBDxx0 TOSHIBA 2,5" USB terminal pinout wanted (if a
PostPosted: January 26th, 2017, 11:20
Here you are
Mikippp
PostPosted: January 26th, 2017, 11:23
Have you soldered two pins in the first two holes of the row?
Thank you
PostPosted: January 26th, 2017, 15:12
This would be my guess:
PostPosted: January 26th, 2017, 15:28
Yes confirmed
PostPosted: January 26th, 2017, 16:15
PC-3000
PostPosted: January 27th, 2017, 1:56
I'm waiting a reply from the support
I succeeded reading the ROM
But in both Toshiba and USB utilities I can't find the one to write it.
Apparently there is only the read command :-(
PostPosted: January 27th, 2017, 15:40
Hello Spildit
In other words?
My idea is to avoid heating donor boards moving and removing chips.
So my point of reading the ROM is next to write it in the donor board.
PostPosted: January 28th, 2017, 2:28
Well.. if any ROM code compatibility checking is possible, the thing sounds as it could be possible to run a "loolks like smooth" process.
The idea is to do as with WD drives. There read from the USB and write into the SATA works straight with all the USB boards numbers/models (except one that makes me crazy, but that's anbother story)
PostPosted: January 29th, 2017, 2:27
Hello
No, my last sentence was referred to all WD USB boards.
This whole post is related to achieve the same as WD on Toshiba MQ USB
PostPosted: January 29th, 2017, 14:03
Yes
Some experiments are needed
First recovery :-)
Next let's see
PostPosted: January 29th, 2017, 15:49
Does the idea of a compatible ROM make any sense for Toshiba drives? If the firmware is mostly contained within the ROM, and if the SA contains only drive specific stuff like SMART and G-list, then does it matter if the ROM firmware is a different version?
PostPosted: August 4th, 2021, 5:52
Hello
any update about read ROM through terminal on TOSHIBAs MQxxUxxx (USB)
then write the ROM on the corresponding SATA board?
Yes, to avoid heating the SATA donors boards
Thank you
PostPosted: August 4th, 2021, 6:28
PC3k can read it but not write, i guess MRT can read it too (could somebody confirm?), writing is possible using a terminal prog (on most families).
PostPosted: August 4th, 2021, 17:13
Corsari wrote:
Hello
Thank you
Alternative is reading ROM in circuit via clip and programmer. Have not physically moved a ROM on a hardrive for years :)
Digitalsupport Data Recovery
https://digitalsupport.dk
Users browsing this forum: No registered users and 57 guests
