 Post subject: HDD WD30EFRX shows sata gen2 transfer instead sata gen3
PostPosted: December 9th, 2024, 6:07
Hi there, I have problem with one of four drives in Desktop and need help
hard drive shows sata gen2 (SATA/300) instead of sata gen3, while other drives show normaly sata3 (SATA/600) on the same cable and sata connector on motherboard
Motherboard is ASUS prime z270-p 4x SATA 6Gbps, but tried on 2 more computers, the result is the same.
Is there a tool (WD) to change the transfer? If not, which module in the WD firmware is responsible for the mode transfer (HDD alias is Diablo3S)
Thanks in advance
Info
In CrystalDiskInfo: SATA/300 | SATA/300 instead SATA/600 | SATA/600
In HD Sentinel: Hard Disk Summary
Hard Disk Number,4
Interface,S-ATA II
Disk Controller,"Intel(R) 300 Series Chipset Family SATA AHCI Controller (AHCI) [VEN: 8086, DEV: A282] Version: 18.37.7.1013, 2-6-2023"
Disk Location,"Bus Number 0, Target Id 3, LUN 0"
Hard Disk Model ID,WDC WD30EFRX-68EUZN0
Firmware Revision,01.05C.A
Hard Disk Serial Number,WD-WCC4N4Rxxxxx
Total Size,2861585 MB
Power State,Active
Device Type,"Removable, safely remove required"
Logical Drive(s)
Logical Drive,E: [New Volume]
ATA Information
Hard Disk Cylinders,5814021
Hard Disk Heads,16
Hard Disk Sectors,63
ATA Revision,ACS-2
Transport Version,SATA Rev 3.0
Total Sectors,732566646
Bytes Per Sector,4096 [Advanced Format]
Multiple Sectors,16
Error Correction Bytes,0
Unformatted Capacity,2861588 MB
Maximum PIO Mode,4
Maximum Multiword DMA Mode,2
Highest Possible Transfer Rate,S-ATA II Signaling Speed (3 Gps)
Negotiated Transfer Rate,S-ATA II Signaling Speed (3 Gps)
Minimum multiword DMA Transfer Time,120 ns
Recommended Multiword DMA Transfer Time,120 ns
Minimum PIO Transfer Time Without IORDY,120 ns
Minimum PIO Transfer Time With IORDY,120 ns
ATA Control Byte,Valid
ATA Checksum Value,Valid
Victoria 5.37
Model: WDC WD30EFRX-68EUZN0
Firmware 01.05C.A
Serial WD-WCC4N4Rxxxxx
Capacity 5860533168 LBAs 3,0 TB
CHS: 16383/16/63 8 GB
S.M.A.R.T Enabled, Errlog, Selftest
Cache 17,9 MB; L/A=ON; Wr=ON; ok
Support LBA, HPA, DLM, DCO, DMA UDMA-6
Erase Time ~ 7 hours 8 minutes
Security OFF, Frozen Frozen!
ATA-8: SATA2, NCQ, PEC, SCT, SFDLM, WrUnk
SCT: AC2, AC3, AC4, AC5
Sector Logic 512 bytes Phys 4096
Drive technical info:
Date: 05-11-2017
Alias: 'DIABLO3S'
RAM chip: 64 MB
Disks: 3
Heads: 6 phys / 6 active
Zones: 61
Wedges: 512
Real RPM: 5400
 Post subject: Re: HDD WD30EFRX shows sata gen2 transfer instead sata gen3
PostPosted: December 9th, 2024, 7:03
Check the DCO settings with HDAT2.
That said, you will not see a discernible difference in performance between 3Gbps and 6Gbps. That's because the drive's maximum sustained transfer rate is about 150MB/s.
PostPosted: December 9th, 2024, 9:53
Thanx for the quick response, I know that the drive can't even reach the full speed of the sata 2 interface, but I want to know what is the cause of this, why it does not support sata 6gbps and is it a bug in the wd firmware
HDAT2 shows:
settings
DCO status: frozen
CMD7 DEV6 HIGH5 MID4 LOW3 CNT2 FEA1
00B1h 0040h 0000h 0000h 0000h 0000h 00C2h
0051h 0040h 0000h 0000h 0000h 0000h 0004h
on raw "modify" (same results)
nothing happens
PostPosted: December 9th, 2024, 14:39
https://forum.hddguru.com/viewtopic.php?f=7&t=42424&mobile=desktop
PostPosted: December 9th, 2024, 14:47
in the meantime i did it but it has no function for change trasfer except UDMA
PostPosted: December 9th, 2024, 14:57
I suspect that firmware module 0x02 or 0x0C would have this setting, but I don't know which byte(s).
The demo version of WDMarvel can read these modules.
I'm assuming that the OPT1 jumper is not installed.
