 Post subject: HD Seagate plug then my PC Hang
PostPosted: July 26th, 2006, 7:45
I have HD seagate 40 GB P/N:9W1021-301
My PC is OK / normal when there is no HD
But if I plug Power Supply HD, my PC cannot turn on
I already change to try and test with 2 other PC and result is same,
When I plug Power HD, PC cannot turn on.
What going on with my HD?
 Post subject:
PostPosted: July 26th, 2006, 8:55
maybe there must be some thing joined in ur pcb eg any componenet try removing the pcb and clena it using thinner or IP .
myay be it can work
 Post subject:
PostPosted: July 26th, 2006, 11:55
hi,
TVS is shorted probably. and maybe other components too.
 Post subject:
PostPosted: July 26th, 2006, 20:54
Yeah, I think my HD shorted
And how to fix it.
Change board HD or anything, please help me.
Kapak.
 Post subject:
PostPosted: July 27th, 2006, 2:39
in many cases U only have to remove the TVS, the drive will start, U may save the data, but I don't recommend using that drive without the TVS.
 Post subject:
PostPosted: July 27th, 2006, 3:59
Hey Pepe,
What do you mean by "TVS" :shock:
Is it a TV channel we don't know about?!
If you mean the diode between the 12V input and the ground , I would agree with you... :P
 Post subject:
PostPosted: July 27th, 2006, 4:06
if u dont have the knowledge repairing or soldering components dont try repairing the PCB just change it or get it repaired by some professional
 Post subject:
PostPosted: July 31st, 2006, 21:16
Can U decribe or send some picture where is it ?
Thank's.
 Post subject:
PostPosted: August 3rd, 2006, 6:16
hi
@rameez i agree with him loosing a quarter of penny on professional service is much better than loosing your files. :)
Atty. of kiyot:
Be the edge in the cutting edge!
 Post subject:
PostPosted: August 5th, 2006, 5:20
[quote="BGman]
If you mean the diode between the 12V input and the ground , I would agree with you... :P[/quote]
TVS=Transient Voltage Suppressor
 Post subject: To Pepe
PostPosted: August 5th, 2006, 13:24
Yeah, we are talking about the same thing...
TVS, but it's a diode anyway.
Users browsing this forum: Google [Bot], jimmydata and 66 guests
