 Post subject: About changing pcbs
PostPosted: April 13th, 2007, 3:21
Hello to all ,
I have a little confusion about changing pcbs of Maxtor drives as my post earlier i asked that some pcbs have ROM chip and some dont , I need to know that if i have a pcb with ROM chip present and one that doesnot have ROM chip and both pcbs are identical can i change them both with each other and also solder the ROM chip to the pcb that doesnot have ROM chip and connect to hdd will it work ?
I am working with the calipso drives 6y80 series and the serial ROM chip .
Thanks .
 Post subject:
PostPosted: April 13th, 2007, 15:11
U don't need to put a rom chip if the PCB doesn't contain one.
In this case the ROM is masked in the processor already.
regards,
 Post subject:
PostPosted: April 13th, 2007, 16:14
thanks for reply
So in this case i have to rewrite ROM if its clicking on the other pcb.
or there can be any other reason .
 Post subject:
PostPosted: April 13th, 2007, 16:42
You want to rewrite masked Rom?
DataRecovery.bg
 Post subject:
PostPosted: April 14th, 2007, 2:18
Yes , Why is it not possible ?
 Post subject:
PostPosted: April 14th, 2007, 16:27
http://forum.hddguru.com/howto-how-to-r ... t5977.html
 Post subject:
PostPosted: April 15th, 2007, 4:18
thanks for reply but i need to rewrite masked ROM there is nothing about that in the topic u gave link of .
 Post subject:
PostPosted: April 15th, 2007, 4:30
It is not possible to rewrite masked ROM !!!
http://www.techweb.com/encyclopedia/def ... masked+ROM
You must use the logic board with correct version of masked ROM in CPU
Mikippp
 Post subject:
PostPosted: April 15th, 2007, 6:46
Thanks for reply
I have many hdd with Corrupted Rom code the hdd is Maxtor 6e040l0 and it shows Maxtor N40p NAR63G4Z After loading Rom from LDR it shows Maxtor 6e040l0 Nar61590 and works perfectly after that after restart the hdd returns to its the same state what to do now ?
 Post subject:
PostPosted: April 15th, 2007, 14:32
rameez
Why are you saying that the problem is with ROM?
 Post subject:
PostPosted: April 15th, 2007, 15:14
Because this is showing invalid ROM code : NAR63G4Z .
And after i load ROM from LDR the ROM code changes to its ok state NAR61590 .
 Post subject:
PostPosted: April 15th, 2007, 15:44
Problem is in SA... not in logic board...
HDD have defects in SA / corrupted SA modules...
Mikippp
 Post subject:
PostPosted: April 15th, 2007, 16:49
no modules are currupt after loading the LDR i checked the SA found no errors in modules then i checked the Surface of SA no errors found .
 Post subject:
PostPosted: April 16th, 2007, 1:47
If no errors are found in SA... - Regenerate translator...
PC-3000 Demo Video
Mikippp
 Post subject:
PostPosted: April 16th, 2007, 2:43
did that too "Translator regenerated Successfully" .
 Post subject:
PostPosted: April 17th, 2007, 16:09
rameez
That code is perfectly valid. "Z" at the end means "system area is damaged " :wink:
 Post subject:
PostPosted: April 17th, 2007, 16:55
maysoft wrote:
rameez
the end code Z indicates that the SA is damaged but did u see the before the Z NAR6"3G4"Z that shows that this is because of ROM , this code comes when hdd in safe mode .
I fixed the problem by the way some idiot replace pcb with another mismatching pcb as u know there are two kinds of pcbs one with external serial ROM chip and one with masked ROM chip i changed it with the external ROM chip . now hdd ok .
Thank you all for help .
