 Post subject: STOPPED ENGINE (SP1644N REV A)
PostPosted: January 25th, 2008, 14:11
Hi to all!!
Stopped engine, I know that they exist you vary techniques to unlock, however before you make would like it to exactly have some stories of cases similar or it model of hd (SP1644N REVA P80M 2007,02)
I know that here they exist expert in hdds SAMSUNG!! :mrgreen:
:vo:
Нет ничего невозможного
 Post subject: Re: STOPPED ENGINE (SP1644N REV A)
PostPosted: January 28th, 2008, 7:15
sempre wrote:
Hi to all!!
:vo:
Somebody has some here help?
:vo:
PostPosted: January 29th, 2008, 16:35
sempre wrote:
sempre wrote:
Hi to all!!
:vo:
:vo:
Plus one it will detail platter (one) is disaligned!
:vo:
Help??
PostPosted: January 30th, 2008, 8:21
Online
Hi
what is your question exactly?
PostPosted: January 30th, 2008, 9:49
Hi pepe!
how I must make to unlock and to try to recovery the data of this hdd? :mrgreen:
Thanks advance!!
:vo:
PostPosted: January 30th, 2008, 17:51
Online
Yes, either free up the spindle or swap platters and align them.
There's no easy way...
PostPosted: February 11th, 2008, 15:11
Hi to all!!
leaves to know I, somebody already decided some here similar case to this?
PostPosted: February 12th, 2008, 15:11
i had the same problem but in older samsing drive V9 and victor i changed the pcb and the drive worked perfectly .
PostPosted: February 12th, 2008, 16:31
Hi rameez!
In this in case that the engine is stopped, it is not problem with pcb! :shock:
Thanks for reply!
:vo:
PostPosted: February 16th, 2008, 2:05
I have some 3 disk refurbished maxtors Platinum 200GB that were like this, from USB caddies, spindles were stuck from being dropped and one disk was slipped also. I used a piston ring compressor (like mechanics use) similar to the platter exchange tool, clamped it around the platters, loosened the fixing screws, and re-tightened them to help align them. I had success with 3 out of 6 this way to re-align the disks. I freed the spindles with two small screwdrivers inserted into the hub holes, and another to help turn the spindle until it freed up.
Like this without crimps on edge http://www.mytoolstore.com/kd/kdengi08.html
Platter exchange tool $2000.00
This one $15.00 :) :)
I think ST is a sub company of Lucas
PostPosted: February 16th, 2008, 2:23
Just to show how I freed up http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/barracuda-7200-10-fell-plates-won-t-spin-t7040.html
PostPosted: February 18th, 2008, 15:19
Thanks for help (Shortscurcuits )!
Users browsing this forum: No registered users and 75 guests
