 Post subject: Seagate 7200.9 ST3160812A
PostPosted: February 17th, 2008, 18:56
Hello. It is necessary to keep the information from a disk. In the terminal writes:
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 12-07-05 09:13
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Slave
CE Log ErrCode=43 LBA=551a Type=5 Add To Pending 551a
AT Er 00 Nwt Er 43 RdWr 00027.00.0008
ATA St 50 Er 00 Op e5 b,0000/0/00,00 ff 00
Niwot: 9ff79ff7 b6 9ff79ff7.1.6b8 0000 005f 0000 006a
CE Log ErrCode=43 LBA=551c Type=4 Remove from Pending 551c
AT Er 00 Nwt Er 43 RdWr 00027.00.0009
DiskAccess ReadSector EC=43 at 000027.00.0009
CE Log ErrCode=43 LBA=551d Type=5 Add To Pending 551d
AT Er 00 Nwt Er 43 RdWr 00027.00.000a
DiskAccess ReadSector EC=43 at 000027.00.000a
CE Log ErrCode=43 LBA=551e Type=5 Add To Pending 551e
AT Er 00 Nwt Er 43 RdWr 00027.00.000b
CE Log ErrCode=43 LBA=551f Type=4 Remove from Pending 551f
AT Er 00 Nwt Er 43 RdWr 00027.00.000c
DiskAccess ReadSector EC=43 at 000027.00.000c
CE Log ErrCode=43 LBA=5520 Type=5 Add To Pending 5520
AT Er 00 Nwt Er 43 RdWr 00027.00.000d
DiskAccess ReadSector EC=43 at 000027.00.000d
CE Log ErrCode=43 LBA=5521 Type=5 Add To Pending 5521
AT Er 00 Nwt Er 43 RdWr 00027.00.000e
DiskAccess ReadSector EC=43 at 000027.00.000e
By pressing ^Z leaves in mode T>
Eng Rev = .0B5
TONKA2 - 1_Disk 3.AAE 12-07-05 09:16 AAE,1D_P_013_N0,4T
CERT Rev = .08G
NONE
Mask Rom Rev = M-31
Unique Descriptor = .3N0
How to disconnect the test? The help is very necessary...
 Post subject: Re: Seagate 7200.9 ST3160812A
PostPosted: February 18th, 2008, 10:27
Very common on Seagate, a weak or bad head, or Media defects, u should be tried some tests at the MHA , on terminal levels to check that some times if its Media defect and u did the head swap the problem still“s, so un first u need to get answers from Seagate Engineering Tests, if u are getting T> check AGE, if u reach DRDY DSC u get a chance tried to controlled by hardware to get sectors, if u dont know that, send to a DR company
Best Regards
PostPosted: February 26th, 2008, 15:32
Did u start any test on the drive ?
PostPosted: February 27th, 2008, 12:51
agree beto, sometimes it can ready with age=50 but cannt read any sector.
PostPosted: February 27th, 2008, 16:51
head problem dear.
DF :)
DF :)
www.datatracksystem.net
Users browsing this forum: Majestic-12 [Bot] and 67 guests
