 Post subject: SP0822N
PostPosted: March 18th, 2008, 15:04
Hi to all!
When binding hdd does not turn the engine!
e recognizes it as: BOOT CODE - HANARO 2 ENGINE REV1
FW: HA100-00 LBA: 0 SN:
The problem is in the PCB...
How I can solve this problem?
:vo:
Нет ничего невозможного
 Post subject: Re: SP0822N
PostPosted: March 18th, 2008, 15:37
Change the PCB and swap ROM
PostPosted: March 19th, 2008, 15:45
this problem also occurs in ROM data curruption also check rom contents.
PostPosted: March 19th, 2008, 16:36
If the drive has motor directly connected to the PCB via pins (Maxtor style) , remove tin, clean PCB with defluxer, bend the pins toward the PCB so they're going to make a steady contact. If this solves, OK. Otherwise the problem is in the quality of the solder of the PCB or ROM corrupted (flash correct main code for that drive). Other way : check with a suitable matching PCB.
Regards.
Users browsing this forum: Majestic-12 [Bot] and 72 guests
