 Post subject: ST3500841A pcb broken
PostPosted: September 29th, 2008, 5:53
Hi everybody!
I have a Seagate model ST3500841A 7200.9 Barracuda and 500 GB of space. My pcb is broken because there is no boot noise when I plug it. I have found a disk with the same model, space, etc but I must go to the store te see if pcb firmware is the same.
My firmware is 3.AAD. What happends if I change pcb of same model but with differents firmwares to restore data?
Thanks in advance
 Post subject: Re: ST3500841A pcb broken
PostPosted: September 29th, 2008, 6:51
It won't work.
Even with same fw version, it quite possibly won't work either.
PostPosted: September 29th, 2008, 7:01
pcimage wrote:
It won't work.
And which is the solution? To pay? :cry:
Thanks in advance
PostPosted: September 29th, 2008, 8:18
If the data is important, Yes. That's by far the safest route. If it's not important, give it a try. You won't have much to lose.
PostPosted: September 29th, 2008, 8:42
Any decent DR company should be able to do this at a reasonable price and not rip you off.
We're in UK and work on a difficulty of job basis, not how valuable the data is. ;-)
Are you 100% sure the drive is dead? (i.e. not even a slight tick or faint buzz when you apply power?)
Cheers
Sean
PostPosted: September 29th, 2008, 9:40
Cheers
Sean
I'm in Spain. There is no sound when I apply power. And data it's important for me. There are some photographic works here. :cry:
Cheers
PostPosted: September 29th, 2008, 9:52
Well, if you're prepared to ship to UK, I can take a look for you.
PostPosted: September 29th, 2008, 9:57
Can you post me price by pm? Thanks in advance.
Cheers :wink:
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 74 guests
cron
