 Post subject: Excelstor Calisto 80GB J880
PostPosted: August 18th, 2009, 18:26
Hi to all,
I have got an 80GB Excelstor, Calisto hard drive (details below):
Model: J880
Firmware Rev: PF20A21B
Date code: 20060623
0A29180
Drive spins up, but does not calibrate, well it tries to, but for some reason cannot.
Is there anyone who had same problem and dealt with successfully? Is there any chance to fix the drive so it gets detected?
Thank you in advance for your help.
Regards,
Martin.
 Post subject: Re: Excelstor Calisto 80GB J880
PostPosted: August 18th, 2009, 18:35
AFAIK, this is a Hitachi/IBM remanufactured HDD.
Can you post a picture of the drive + PCB to confirm and further diagnose?
Data Recovery Ireland
PostPosted: August 19th, 2009, 1:24
I would better say "refurbished" than "remanufactured"...
PostPosted: August 19th, 2009, 4:28
As requested, below there are two pics attached.
Drive was open to check if there is any scratch, but there is no scratch on platter.
Using PC3k, when power is on, it shows BSY (green), and then both: DRD & DSC (green) as well.. but nothing happens apart from that. Drive ID cannot be read
Please let me know, what you think.
Regards,
Martin.
PostPosted: August 19th, 2009, 9:03
well DRDY DSC, means reach readiness, but maybe its Aborting all commands, tried to read any sector and check what did u get on ATA registers
PostPosted: August 19th, 2009, 9:25
if you want any help about the "ExcelStor" drive PM ...
* dont listen the BlackST , leave on another Planet
Xronis
T3 Professional Data Recovery
http://www.t3-recovery.com
PostPosted: August 19th, 2009, 11:46
Xronis.... leave "RAKI" instead ... :mrgreen: you nasty boy !!
PostPosted: August 21st, 2009, 11:00
0A29180 BA1686_ - HDS728080PLAT20
Users browsing this forum: Gotdata and 169 guests
