 Post subject: Maxtor diamond max plus 9 80gb
PostPosted: October 18th, 2009, 20:01
hi all
i have a drive thatg would not show id and any data.
i started with pc3000 and was able to use the recovery tool to get the drive to show below
HDD Recovery thru LDR uploading
LDR downloading......................... : Ok
1B overlay loading...................... : Ok
1C overlay loading...................... : Ok
ROM Copy loading........................ : Ok
HDD Soft Reset
Overlaies loading....................... : Ok
HDD Soft Reset
LDR Loading............................. : Ok
Model................................... : Maxtor CALYPSO
FW...................................... : YAR41BW0
Roadmap reading......................... : Ok
Zone allocation table reading........... : Ok
DISK module initialization from recovery : Ok
Model................................... : Maxtor 6Y120L3
Heads map............................... : 3
SA Defects checking Copy0............... : Module 37 reading error. UBA 4 (1) reading error. Drive is not ready
SA Defects checking Copy1............... : Module 37 reading error. UBA 44908 (1) reading error. Drive is not ready
SA Defects reading error
DISK reading............................ : DISK (Copy0) reading error: Module 1F reading error. UBA 8 (1) reading error. Drive is not ready
DISK reading............................ : DISK (Copy1) reading error: Module 1F reading error. UBA 15936 (1) reading error. Drive is not ready
DISK module initialization.............. : Module DISK reading error
Recovery process has been interrupted
from there i cant go any further.
during drive startup it will clikc and spin down several times and then show me the above after the firmwre repair.
after it starts up it bewcmoes ready, stops clickng but cant go any firther.
any thoughts will eb appreciated.
thank yuo
 Post subject: Re: Maxtor diamond max plus 9 80gb
PostPosted: October 18th, 2009, 20:25
Fix SA
www.datarecoveryne.com
PostPosted: October 18th, 2009, 20:52
just noticed there is a big scratch on the drive right where the heads are parking.
any hope ?
PostPosted: October 18th, 2009, 21:47
any hope ?
hi,
are you sure head is ok?
data recovery service[/b]
PostPosted: October 18th, 2009, 23:30
There is always hope. In this situation also.
PostPosted: October 19th, 2009, 1:20
any hope ?
I have a solution in this case.
If you interested....
PM me.
Janos
Users browsing this forum: Majestic-12 [Bot] and 154 guests
