 Post subject: WD, need to know if this is the original PCB
PostPosted: February 17th, 2010, 0:00
I just got a drive today that gives no indication of power, however upon looking at the PCB there is an unfilled screw hole, and no support underneath for a screw. I was hoping I could provide the information from the PCB and the drive label to see if this is correct.
Model: WD3200AAJB-00J3A0
PCB revision: 2061-701596-A00 12P
Thanks for the help.
 Post subject: Re: WD, need to know if this is the original PCB
PostPosted: February 17th, 2010, 2:00
Most manufacturers appear to espouse the philosophy of just-in-time manufacturing. This means that the date code on the label should match the date codes on the chips.
IC date codes are most often encoded in YYWW or YWW format, where Y=year and W=week.
If you can upload some detailed photographs, maybe someone will be able to assist you.
PostPosted: February 17th, 2010, 10:36
The 2 that i have have a board rev of 2060-701596-001 Rev P1
both are the exact same model as well
WD3200AAJB-00J3A0
also both of them look like they are missing a screw as well
PostPosted: February 17th, 2010, 15:00
fzabkar: I didn't even think about checking those dates, thanks for turning my brain on.
CleanRoom: Thanks for the information
I had just never seen one like that before, caught me by suprise. Now I get to figure out where the power issue lies ;)
Thanks again guys
Users browsing this forum: No registered users and 164 guests
