Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Dreadfully slow WD15EADS - 00P8B0 1.5TB
PostPosted: May 14th, 2012, 16:25
You won't mark them as bad with MHDD as you wish : it's just cosmetic.
If the drive is intended for storage of stuff with NO importance at all i.e. temporary download or media storage like movies of no importance etc. (in a nutshell : in case of data loss the only effective loss is time to download it / fill it again) then the answer may be " uh... yes... try".
A more effective solution would be finding someone in your area who can professionally refurbish it for few $ / EUR (assuming they have the gear and know what to do) , in this case you can squeeze out some life (years maybe) from the disk. I could have been of help but I'm at the opposite corner of this world :(
P.S. don't make the disk run hot for NO reason. I mean 40 deg C is the limit.
PostPosted: May 16th, 2012, 1:18
when you say that there's a way to refurbish it do you mean it's a complicated software procedure or do I also need specific hardware as well? If it's only software, can you please name them so I can look them up?
It's only an HD that is rarely turned on and now that it's problematic it will most possibly stay inactive after copying back the files until a new one is bought. The files in there are indeed downloads of minor importance like you described above.
Oh, and something else, about what you said on HD temperature: is it possible that high temps cause physical faults? Problem is, I live in southern Greece and summer temperatures go well above 30C for months...
PostPosted: May 16th, 2012, 12:53
Post SMART again now that you have run the erase
PostPosted: May 16th, 2012, 15:15
-- Physical Disk Information - Disk: #3: WDC WD15EADS-00P8B0 --
    Hard Disk Summary
    Hard Disk Number . . . . . . . . . . . . . . . . : 3
    Interface  . . . . . . . . . . . . . . . . . . . : S-ATA II
    Disk Controller  . . . . . . . . . . . . . . . . : Standard Dual Channel PCI IDE Controller (ATA)
    Disk Location  . . . . . . . . . . . . . . . . . : Channel 1, Target 1, Lun 0, Device: 1
    Hard Disk Model ID . . . . . . . . . . . . . . . : WDC WD15EADS-00P8B0
    Firmware Revision  . . . . . . . . . . . . . . . : 01.00A01
    Hard Disk Serial Number  . . . . . . . . . . . . : WD-WCAVU0122010
    Total Size . . . . . . . . . . . . . . . . . . . : 1430796 MB
    Power State  . . . . . . . . . . . . . . . . . . : Active
    Current Temperature  . . . . . . . . . . . . . . : 25 °C
    Maximum Temperature (Ever Measured)  . . . . . . : 45 °C, 27/4/2012 12:20:18 πμ
    Minimum Temperature (Ever Measured)  . . . . . . : 21 °C, 23/4/2012 7:14:13 μμ
    Maximum Temperature (During Entire Lifespan) . . : 46 °C
    Power On Time  . . . . . . . . . . . . . . . . . : 57 days, 11 hours
    Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
    Health . . . . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
    Performance  . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
    The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
      No actions needed.
    ATA Information
    Hard Disk Cylinders  . . . . . . . . . . . . . . : 2907021
    Hard Disk Heads  . . . . . . . . . . . . . . . . : 16
    Hard Disk Sectors  . . . . . . . . . . . . . . . : 63
    ATA Revision . . . . . . . . . . . . . . . . . . : ATA8-ACS
    Transport Version  . . . . . . . . . . . . . . . : SATA Rev 2.6
    Total Sectors  . . . . . . . . . . . . . . . . . : 2930277168
    Bytes Per Sector . . . . . . . . . . . . . . . . : 512
    Buffer Size  . . . . . . . . . . . . . . . . . . : 32767 KB
    Multiple Sectors . . . . . . . . . . . . . . . . : 16
    Error Correction Bytes . . . . . . . . . . . . . : 50
    Unformatted Capacity . . . . . . . . . . . . . . : 1430799 MB
    Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
    Maximum Multiword DMA Mode . . . . . . . . . . . : 2
    Active Multiword DMA Mode  . . . . . . . . . . . : 2
    Maximum UDMA Mode  . . . . . . . . . . . . . . . : 300 MB/s (6)
    Minimum Multiword DMA Transfer Time  . . . . . . : 120 ns
    Recommended Multiword DMA Transfer Time  . . . . : 120 ns
    Minimum PIO Transfer Time Without IORDY  . . . . : 120 ns
    Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
    ATA Control Byte . . . . . . . . . . . . . . . . : Valid
    ATA Checksum Value . . . . . . . . . . . . . . . : Valid
    Acoustic Management Configuration
    Acoustic Management  . . . . . . . . . . . . . . : Supported
    Acoustic Management  . . . . . . . . . . . . . . : Disabled
    Current Acoustic Level . . . . . . . . . . . . . : Max performance and volume (FEh)
    Recommended Acoustic Level . . . . . . . . . . . : Min performance and volume (80h)
    ATA Features
    Read Ahead Buffer  . . . . . . . . . . . . . . . : Supported, Enabled
    DMA  . . . . . . . . . . . . . . . . . . . . . . : Supported
    Ultra DMA  . . . . . . . . . . . . . . . . . . . : Supported
    S.M.A.R.T. . . . . . . . . . . . . . . . . . . . : Supported
    Power Management . . . . . . . . . . . . . . . . : Supported
    Write Cache  . . . . . . . . . . . . . . . . . . : Supported
    Host Protected Area  . . . . . . . . . . . . . . : Supported
    Advanced Power Management  . . . . . . . . . . . : Not supported
    Extended Power Management  . . . . . . . . . . . : Not supported
    Power Up In Standby  . . . . . . . . . . . . . . : Supported
    48-Bit LBA Addressing  . . . . . . . . . . . . . : Supported
    Device Configuration Overlay . . . . . . . . . . : Supported
    IORDY Support  . . . . . . . . . . . . . . . . . : Supported
    Read/Write DMA Queue . . . . . . . . . . . . . . : Not supported
    NOP Command  . . . . . . . . . . . . . . . . . . : Supported
    Trusted Computing  . . . . . . . . . . . . . . . : Not supported
    64-Bit World Wide ID . . . . . . . . . . . . . . : 0150E24EAD58A9CA
    Streaming  . . . . . . . . . . . . . . . . . . . : Not supported
    Media Card Pass Through  . . . . . . . . . . . . : Not supported
    General Purpose Logging  . . . . . . . . . . . . : Supported
    Error Logging  . . . . . . . . . . . . . . . . . : Supported
    CFA Feature Set  . . . . . . . . . . . . . . . . : Not supported
    CFast Device . . . . . . . . . . . . . . . . . . : Not supported
    Long Physical Sectors (1)  . . . . . . . . . . . : Not supported
    Long Logical Sectors . . . . . . . . . . . . . . : Not supported
    Write-Read-Verify  . . . . . . . . . . . . . . . : Not supported
    NV Cache Feature . . . . . . . . . . . . . . . . : Not supported
    NV Cache Power Mode  . . . . . . . . . . . . . . : Not supported
    NV Cache Size  . . . . . . . . . . . . . . . . . : Not supported
    Free-fall Control  . . . . . . . . . . . . . . . : Not supported
    Free-fall Control Sensitivity  . . . . . . . . . : Not supported
    SSD Features
    Data Set Management  . . . . . . . . . . . . . . : Not supported
    TRIM Command . . . . . . . . . . . . . . . . . . : Not supported
    Deterministic Read After TRIM  . . . . . . . . . : Not supported
    S.M.A.R.T. Details
    Off-line Data Collection Status  . . . . . . . . : Suspended By Interrupting Command From Host
    Self Test Execution Status . . . . . . . . . . . : Successfully Completed
    Total Time To Complete Off-line Data Collection  : 33780 seconds
    Execute Off-line Immediate . . . . . . . . . . . : Supported
    Abort/restart Off-line By Host . . . . . . . . . : Not supported
    Off-line Read Scanning . . . . . . . . . . . . . : Supported
    Short Self-test  . . . . . . . . . . . . . . . . : Supported
    Extended Self-test . . . . . . . . . . . . . . . : Supported
    Conveyance Self-test . . . . . . . . . . . . . . : Supported
    Selective Self-Test  . . . . . . . . . . . . . . : Supported
    Save Data Before/After Power Saving Mode . . . . : Supported
    Enable/Disable Attribute Autosave  . . . . . . . : Supported
    Error Logging Capability . . . . . . . . . . . . : Supported
    Short Self-test Estimated Time . . . . . . . . . : 2 minutes
    Extended Self-test Estimated Time  . . . . . . . : 385 minutes
    Conveyance Self-test Estimated Time  . . . . . . : 5 minutes
    Last Short Self-test Result  . . . . . . . . . . : Never Started
    Last Short Self-test Date  . . . . . . . . . . . : Never Started
    Last Extended Self-test Result . . . . . . . . . : Never Started
    Last Extended Self-test Date . . . . . . . . . . : Never Started
    Last Conveyance Self-test Result . . . . . . . . : Never Started
    Last Conveyance Self-test Date . . . . . . . . . : Never Started
    Security Mode
    Security Mode  . . . . . . . . . . . . . . . . . : Supported
    Security Erase . . . . . . . . . . . . . . . . . : Supported
    Security Erase Time  . . . . . . . . . . . . . . : 172 minutes
    Security Enhanced Erase Feature  . . . . . . . . : Supported
    Security Enhanced Erase Time . . . . . . . . . . : 172 minutes
    Security Enabled . . . . . . . . . . . . . . . . : No
    Security Locked  . . . . . . . . . . . . . . . . : No
    Security Frozen  . . . . . . . . . . . . . . . . : Yes
    Security Counter Expired . . . . . . . . . . . . : No
    Security Level . . . . . . . . . . . . . . . . . : High
    Serial ATA Features
    S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
    S-ATA I Signaling Speed (1.5 Gps)  . . . . . . . : Supported
    S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
    S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Not supported
    Receipt Of Power Management Requests From Host . : Supported
    PHY Event Counters . . . . . . . . . . . . . . . : Supported
    Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
    DMA Setup Auto-Activate Optimization . . . . . . : Supported, Disabled
    Device Initiating Interface Power Management . . : Not supported
    In-Order Data Delivery . . . . . . . . . . . . . : Not supported
    Asynchronous Notification  . . . . . . . . . . . : Not supported
    Software Settings Preservation . . . . . . . . . : Supported, Enabled
    Native Command Queuing (NCQ) . . . . . . . . . . : Supported
    Queue Length . . . . . . . . . . . . . . . . . . : 32
    Disk Information
    Disk Family  . . . . . . . . . . . . . . . . . . : Caviar Green
    Form Factor  . . . . . . . . . . . . . . . . . . : 3.5"
    Capacity . . . . . . . . . . . . . . . . . . . . : 1500 GB (1500 x 1.000.000.000 bytes)
    Number Of Disks  . . . . . . . . . . . . . . . . : 3
    Number Of Heads  . . . . . . . . . . . . . . . . : 6
    Disk Interface . . . . . . . . . . . . . . . . . : Serial-ATA/300
    Buffer-Host Max. Rate  . . . . . . . . . . . . . : 300 MB/seconds
    Buffer Size  . . . . . . . . . . . . . . . . . . : 32768 KB
    Drive Ready Time (Typical) . . . . . . . . . . . : 14.5 seconds
    Average Seek Time  . . . . . . . . . . . . . . . : ? ms
    Track To Track Seek Time . . . . . . . . . . . . : ? ms
    Full Stroke Seek Time  . . . . . . . . . . . . . : ? ms
    Width  . . . . . . . . . . . . . . . . . . . . . : 101,6 mm (4,0 inch)
    Depth  . . . . . . . . . . . . . . . . . . . . . : 147,0 mm (5,8 inch)
    Height . . . . . . . . . . . . . . . . . . . . . : 26,1 mm (1,0 inch)
    Weight . . . . . . . . . . . . . . . . . . . . . : 730 grams (1,6 pounds)
    Acoustic (Idle)  . . . . . . . . . . . . . . . . : 2,4 Bel
    Acoustic (Min Performance And Volume)  . . . . . : 2,5 Bel
    Acoustic (Max Performance And Volume)  . . . . . : 2,9 Bel
    Required Power For Spinup  . . . . . . . . . . . : 1.759 mA
    Power Required (Seek)  . . . . . . . . . . . . . : 6,0 W
    Power Required (Idle)  . . . . . . . . . . . . . : 3,7 W
    Power Required (Standby) . . . . . . . . . . . . : 0,8 W
    Manufacturer . . . . . . . . . . . . . . . . . . : Western Digital Corporation
    Manufacturer Website . . . . . . . . . . . . . . : http://www.westerndigital.com/en/products
    S.M.A.R.T.
No.  Attribute                Thre.. Value  Worst  Data                Status                   Flags
1    Raw Read Error Rate      51     200    200    000000000000        OK                       Self Preserving, Error-Rate, Performance, Statistica..
3    Spin Up Time             21     178    178    0000000017C3        OK                       Self Preserving, Performance, Statistical, Critical
4    Start/Stop Count         0      100    100    00000000008A        OK (Always passing)      Self Preserving, Event Count, Statistical
5    Reallocated Sectors Co.. 140    200    200    000000000000        OK                       Self Preserving, Event Count, Statistical, Critical
7    Seek Error Rate          0      200    200    000000000000        OK (Always passing)      Self Preserving, Error-Rate, Performance, Statistical
9    Power On Time Count      0      99     99     000000000563        OK (Always passing)      Self Preserving, Event Count, Statistical
10   Spin Retry Count         0      100    100    000000000000        OK (Always passing)      Self Preserving, Event Count, Statistical
11   Drive Calibration Retr.. 0      100    253    000000000000        OK (Always passing)      Self Preserving, Event Count, Statistical
12   Drive Power Cycle Count  0      100    100    00000000005C        OK (Always passing)      Self Preserving, Event Count, Statistical
192  Power off Retract Cycl.. 0      200    200    00000000004A        OK (Always passing)      Self Preserving, Event Count, Statistical
193  Load/Unload Cycle Count  0      200    200    0000000001FD        OK (Always passing)      Self Preserving, Event Count, Statistical
194  Disk Temperature         0      125    104    000000000019        OK (Always passing)      Self Preserving, Statistical
196  Reallocation Event Count 0      200    200    000000000000        OK (Always passing)      Self Preserving, Event Count, Statistical
197  Current Pending Sector.. 0      200    200    000000000000        OK (Always passing)      Self Preserving, Event Count, Statistical
198  Off-Line Uncorrectable.. 0      200    200    000000000000        OK (Always passing)      Self Preserving, Event Count
199  Ultra ATA CRC Error Co.. 0      200    200    000000000000        OK (Always passing)      Self Preserving, Event Count, Statistical
200  Write Error Rate         0      200    200    000000000000        OK (Always passing)      Error-Rate
PostPosted: May 16th, 2012, 17:27
No unfortunately it's pure HW solution out of reach of end users.
Users browsing this forum: Google [Bot], szlaci_s70 and 175 guests
