Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: ST3000DM001 1CH166-510 issue
PostPosted: December 3rd, 2022, 7:36
Ok, I'll do that within 24 hours from now and report back.
I'm really new to all this, can you tell lol
PostPosted: December 3rd, 2022, 20:48
I'm back with a small update.
I've taken a photo of the connection of the serial side of things.
I haven't seen anywhere in the guides that I can find where they connect anything other than RX & TX
I'm hesitant to connect a ground cable due to this.
This is my serial connection:
PostPosted: December 3rd, 2022, 21:14
Gnd is the 4th pin in the hdd's connector, do connect it to the adapter's gnd pin.
On the other hand, is that adapter capable of 1.8V IO?
PostPosted: December 3rd, 2022, 22:15
I will try that today and report back.
I believe I read so in the datasheet.
PostPosted: December 3rd, 2022, 22:58
I ran the CTRL+X command multiple times again and it looks like the ground wire helped?
Trans.
Spin Up
SpinOK
TCC:0014
(P) SATA Reset
Trans.
Spin Up
SpinOK
TCC:0016
(P) SATA Reset
ASCII Diag mode
F3 T>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
      8133 99999999        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.03BF800
      8166       33        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      8174        8        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      8182        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      8190        8        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D917 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      8199        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      8209       10        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      8217        8        0 27  028201 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
        0000 0000 0000 0000 0000 0000 0000 0000
        0001 D719 00D0
        674C 0001 0000 0002 0004 0CF0 18B0 DE74
        0003 0F9F 0F8D 0F78 0F71 0F80 1000 1053
        FE7B 5B07 BB14 53F6 49CC 9AD1 46AE 7B63
        A8F0 6F13 7B7F CFC9 3D1A E4E2 5551 1229
      8217        0        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068487
      8224        7        5 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000421AF L 000000000003 BO 000000 BES 00684C7.0068586.00684C7
      8229        5        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      8245       16      112 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C5BB L 000000003800 BO 000000 BES 0068F67.0148F66.0068F67
      8564      319        9 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      8573        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      8582        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D933 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      8590        8        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      8616       26        7 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF3 L 000000000001 BO 000000 BES 00689E7.0068A26.00689E7
      8623        7        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D280.022D37F.022D280
      8631        8        9 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      8640        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      8648        8       10 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000003DB094 L 000000000001 BO 000000 BES 0241A80.0241ABF.0241A80
      8664       16       60 02  011101 000000 1 00000080 XFR RD USR LBA B 00000000255A L 000000000762 BO 24000E74 VL E89C.3B10
      8724       60       38 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      8762       38       17 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      8779       17        4 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      8784        5        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      8795       11       26 02  011101 000000 1 00000080 XFR RD USR LBA B 000000000000 L 0000000001A8 BO 24000E74 VL 2C9C.0D40
      8918      123       11 02  028101 000000 1 00000080 XFR WR USR LBA B 000000000000 L 0000000001A8 BO 24000E74 VL 3C9C.0D40
      8930       12       19 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      8949       19        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      8958        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      8967        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
ATA  15 Cmds
RW  32 Cmds
        0001 D719 00D0
ASCII Diag mode
F3 T>
ATA  15 Cmds
RW  32 Cmds
        0001 D719 00D0
ASCII Diag mode
F3 T>
ATA  15 Cmds
RW  32 Cmds
        0001 D719 00D0
ASCII Diag mode
F3 T>
ATA  15 Cmds
RW  32 Cmds
        0001 D719 00D0
PostPosted: December 5th, 2022, 6:29
The log looks a lot better, also i can't find anything wrong with the content, other than this:
Trans.
Spin Up
SpinOK
TCC:0014
(P) SATA Reset
Trans.
Spin Up
SpinOK
TCC:0016
(P) SATA Reset
this looks like the drive restarted on its own, perhaps the power connector has bad contact or if is connected through a MOLEX-SATA power adaptor, there might be bad contact in the MOLEX side power connector.
PostPosted: December 5th, 2022, 7:07
That might have just been me not restarting putty between sessions.
Besides that, any suggestions on what to do next?
PostPosted: December 5th, 2022, 10:48
run
T>V4
PostPosted: December 5th, 2022, 23:46
https://drive.google.com/file/d/1WzpAibNUPq9qKAvtn1ArJ6OESTVUYn7b/view?usp=sharing
Too big to paste here, had to make a google doc.
PostPosted: December 6th, 2022, 5:32
yeah, it is having a lot of grown defects but the list is not full, so that's probably not the main problem.
T>F"SerialDebugLevel",7F
what do you get on next powerup?
PostPosted: December 6th, 2022, 5:45
So I write exactly that? Then power down? Anything I need to do at the next power up?
PostPosted: December 6th, 2022, 6:10
yes, repower it. you probably don't need to power the pc down, just reattach the sata power cable
you might want to run it on a spare PSU instead of the PC's own one to make life easier.
the 'T>' part is the prompt, no need to write that of course.
Also, it is still a long way to get this thing recovered using remote control, and it might be worth finding somebody with tools and know-how near you... It should not be overly expensive at this stage.
PostPosted: December 6th, 2022, 6:19
I don't have a spare sadly, but I've got the cable coming out from the case, so it's not too much effort.
I really have zero money I can spare to spend on this. Barely surviving on what money I have as it is.
I'll probably do this command tomorrow as it is getting late and I'm a bit too tired to concentrate on it.
Thanks again for all of your help so far, I really do appreciate it.
PostPosted: December 6th, 2022, 20:11
I pressed CTRL+V thinking I could paste here. I believe that's what cause the 2 following lines.
F3 T>
EchoInterfaceCmds: On
EchoBackgroundActivities: Off
F3 T>F"SerialDebugLevel",7F
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
Update HPA Cap and Save
(D) SATA Reset
Byte:0487:       SerialDebugLevel = 7F
F3 T>
THIS IS THE SECOND SPIN UP
Trans.
Spin Up
SpinOK
TCC:0015
(P) SATA Reset
RAW OFF
PASS
MCMainPOR: Start:
User Data Base  004403D8
Check MCMT Version: Current
MC026: Reconstruction: MCMT Reconstruction Start
[RSRS] 000D
MC022: Reconstruction: HeadPtr was unwritten
MC024: Reconstruction: Completed:
[MCMTWS] Tail/Head 000D 000D
MCMainPOR: MCTStateFlags 0000002A  MCStateFlags 00000041  Tms 000000C2
SP200: MSPMainPOR Start
MSP MainPOR: 00003000  Tms 000000C2  00000092  0000016B
MSP MainPOR: Complete
No Phy: Staggered spin bypass
PostPosted: December 6th, 2022, 21:49
Once you get the terminal notification, just type in V.
F3 T>V
PostPosted: December 6th, 2022, 22:00
I'll do that very shortly and report back
PostPosted: December 6th, 2022, 22:37
Here we go: https://drive.google.com/file/d/1HtkD8q ... sp=sharing
PostPosted: December 7th, 2022, 0:00
Sorry I thought you were following what Pepe had told you earlier. Use V4 and then V40.
PostPosted: December 7th, 2022, 0:16
I've done V4 in the first link, so just a V40?
PostPosted: December 7th, 2022, 7:41
need to find out why...
Users browsing this forum: No registered users and 92 guests
