 Post subject: ST3320613AS 0LBA, 0Gb
PostPosted: December 4th, 2008, 5:29
Location: Zagreb,Hrvatska popravljam diskove "bussy,0LBA" http://www.hddrepair.dzaba.com/
Hi.
I have problem with this drive from subject, after updating motherboard bios, my hdd, after reboot dont have 320Gb but 0Gb and 0 LBA's,
Seatools recognize hdd, same as bios, but there is no SMART enable,or disable, but just SMART = Not Found,
Any try to test drive and with LBA error, only work identify,and firmware upgrade,
did some have this firmware to reupload it to drive?
Should i contact SEAGATE for original full firmware,tho he said to me(helpdesk) that there is no available firmware update for this drive.
[img=http://img234.imageshack.us/img234/8629/66323681sj5.th.gif]
By,
Goran
popust 50% na popravak bussy i 0LBA
 Post subject: Re: ST3320613AS 0LBA, 0Gb
PostPosted: December 4th, 2008, 7:21
Do not waste your time looking for firmware, you will not be able to update it without expensive tools. It is not a mobile phone or DVD player.
If you need the data then send to a pro, otherwise throw it away.
Sorry to be the bearer of this news, but it's the truth!
PostPosted: December 4th, 2008, 9:13
gsustek,
Where are you based ?
<itch>
https://www.mjm.co.uk/
PostPosted: December 4th, 2008, 9:17
scratchy wrote:
gsustek,
<itch>
Croatia,
so if i understand, there is no official update for this disk od maxtor version, that will be able to rewrite firmware and fix hdd?
PostPosted: December 4th, 2008, 9:30
That problems cannot be solved "updating" firmware , this looks like a problems over firmware on platters, called Engineering Cylinders,System Area Diskware, etc,
PostPosted: December 4th, 2008, 11:21
ok. so if i have PC-3000 and firmware from
http://files.hddguru.com/index.php
PostPosted: December 4th, 2008, 12:52
No, FW over hdd´s its not like Flash BIOS over MB, read another posts realated to that to understand
regards
Users browsing this forum: Google [Bot], Majestic-12 [Bot], pepe and 66 guests
