 Post subject: Hitachi Travelstar - not detect
PostPosted: March 18th, 2009, 5:45
Hello all..
i newbie in this hdd repair and i need all of your help to improve my knowledge.
Right now i have software/tool like pc3k and hd doctor for hitachi ibm(salvation) on my company..but by have all of this and don't know how to use it is very shame to me..hihi
my Problem is..
hdd model : atmr, atcs and many more (all 2.5'', ide)
problem : not detect in salvation and pc3k. (but have power coz i heard it spin) (my friend say i have to go into safe mode but i don't know how)
 Post subject: Re: Hitachi Travelstar - not detect
PostPosted: March 18th, 2009, 5:54
Did you read the manual ? There's a lot of explanation provided by manufacturer about setting drives to safe mode.
My Forum
PostPosted: March 18th, 2009, 6:03
Your problem is bigger than a few laptop drives...
PostPosted: March 18th, 2009, 6:53
Banned User
try pcb swap, your drive can have a heads problem, are heads physically going to platter area?
PostPosted: March 18th, 2009, 7:00
helios wrote:
Hello all..
my Problem is..
I assume you are very new to data recovery, and you are attempting recovery from a customers HDD with limited knowledge of the HDD and how it works. You first need to understand what you are doing, and why it needs to be done, then you will have more success at data recovery. The data on your clients drive is most likely of much value to him, so for his sake you should not attempt repairs when you do not know the problem. I would recommend you buy in some donors, and experiment on media where data is not of any importance.
Does PC3K display any lights when your HDD is connected? does HDD click at all? Does HDD reach DRD and DSC? You say you hear it spin, are you sure it is the motor you are hearing and not the sounds of stuck heads?
You will need to give more information about your problem.
PostPosted: March 18th, 2009, 7:02
Also, what do you mean by this:
my Problem is..
You have 1 failed hitachi travelstar, or more?
PostPosted: March 18th, 2009, 7:15
Banned User
if its spinning, is it comming ready?
PostPosted: March 18th, 2009, 8:43
When you buy a product, assure you get the right support, otherwise you are only buying enough rope to hang yourself.
Wisdom pill of the day :mrgreen:
PostPosted: March 18th, 2009, 10:04
Im think on first u should be learn How Hard Disk works before, start with a tool , i.e T13.org to start :D
PostPosted: March 18th, 2009, 14:13
RTFM
Users browsing this forum: No registered users and 163 guests
