 Post subject: HD322HJ - doesn't work and is not detectable.
PostPosted: March 30th, 2009, 3:39
I need some help with my hard drive. 2-3 sec. after power-on I hear a buzzing noice. The report from the terminal is:
--- cut ---
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 018A
tSHOS - Released on 2008/04/18 15:1
2 by sec
DRAM=16MB SoC=26A3
SHOS-(1AC12a9M.a11)
L=00000000,00000000
<SpinOn_2>KeepSpinOn!
RV Circuit Enabled
Temp : 25 degC
SpinOk
mServoStatus1 00000003
ADC Time Out!
ADC Time Out!
ADC Time Out!
ADC Time Out!
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 0184
2 by sec
DRAM=16MB SoC=26A3
SHOS-(1AC12a9M.a11)
L=00000000,00000000
RV Circuit Enabled
Temp : 24 degC
SpinOk
ADC Time Out!
ADC Time Out!
ADC Time Out!
ADC Time Out!
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
pinSpeed_0> UF 7 SpnSpdErr
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
RPM at Handoff: 019F
RV Circuit Enabled
ADC Time Out!
ADC Time Out!
ADC Time Out!
ADC Time Out!
Temp : 24 degC
<SpinAccel_2p1> Accel fails FaultCheck: mSpinAccelCheck1 = 0, mSpinAccelCheck2 =
0, mSpinRPM = 341
<SpinAccelRMaxPhyHead = 0002
1 RPM = 340
<SpinOnRetry> mCOMSENSRty = 0, mAccelRty =
++ SU
MaxPhyHead = 0002
M = 333
MaxPhyHead = 0002
MaxPhyHead = 0002
ADC Time Out!
ADC Time Out!
Temp : 23 degC
0, mSpinRPM = 334
= 1 RPM = 332
++ SU
MaxPhyHead = 0002
RPM = 325
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<SpinOn_4>Report Spin Error!
<CheckSpinSpeed_0> UF 7 SpnSpdErr
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002 MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
PSL
++ SU
MaxPhyHead = 0006
RPM at Handoff: 018F
2 by sec
DRAM=16MB SoC=26A3
SHOS-(1AC12a9M.a11)
L=00000000,00000000
RV Circuit Enabled
Temp : 24 degC
SpinOk
ADC Time Out!
ADC Time Out!
ADC Time Out!
ADC Time Out!
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
RPM at Handoff: 017E
RV Circuit Enabled
ADC Time Out!
ADC Time Out!
ADC Time Out!
ADC Time Out!
Temp : 24 degC
0, mSpinRPM = 338
lRty = 1 RPM = 338
++ SU
MaxPhyHead = 0002
PM = 330
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:0
++ SU
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
MaxPhyHead = 0002
<CheckS
Vol Parking!
PK_3 C: 0 H:1
Unlatch Fail
Vol Parking!
PK_4 C: 0 H:0
LED 1102
LED 1102
LED 1102
LED 1102
LED 1102
LED 1102
LED 1102
LED 1102
--- cut ---
Please, advise me on how I can recover data from my hdd.
Thanks a lot,
Dawid
 Post subject: Re: HD322HJ - doesn't work and is not detectable.
PostPosted: March 30th, 2009, 8:26
hi! :mrgreen:
error in rpm... look error.. :idea:
Нет ничего невозможного
PostPosted: March 30th, 2009, 10:26
Do you think it's a problem with rpm of the hard drive? Or is it the engine failure?
I have another drive of the same kind (three first letters of the serial number are the same). What parts in the broken drive shall I replace with the parts from the one that is working in order to fix it?
Thank for your advice.
Dawid
PostPosted: March 30th, 2009, 10:48
Can be either the PCB (change it from identical drive) , a power supply failure (unlike) or motor. I would suspect the heads too, but motor comes first.
PostPosted: March 30th, 2009, 11:01
Could u post us here that "buzz" sound?
PostPosted: March 30th, 2009, 12:42
yes of course, as attachment I post the "buzz" noise...
any ideas, what should i do with my hdd :(
Thanks,
Dawid
hdd.zip [385.43 KiB]
Downloaded 499 times
PostPosted: March 30th, 2009, 12:50
If you have a PCB from the same model, try that first. See if the buzzing noise goes away at least.
PostPosted: March 30th, 2009, 18:16
Tried like pcimage told u and if the problem still then are spindle or head sticktion problems need to send to a DR professional
PostPosted: March 31st, 2009, 6:25
Thank you very much for your interest and help. I appreciate it a lot.
However, it turned out that my spare Samsung is also damaged :( I have to find another one, and return to this case.
Users browsing this forum: Bing [Bot], Google [Bot] and 109 guests
