 Post subject: Internal western digital hard disk stopped working
PostPosted: May 18th, 2009, 12:21
I'm looking for help on an internal Western digital hard disk drive that does not seem to be getting any power.
The internal hard disk was originaly used on a USB setup however after the unit failed to work I removed it from its housing an plugged it directly into my PC as the slave unit. The hard disk does not spin or seem to get any power. I have ruled out the power to the unit as my other hard disks operate correctly using the same cable. Can anyone help me with this problem on how to get the data from the hard disk.
Elfie
 Post subject: Re: Internal western digital hard disk stopped working
PostPosted: May 18th, 2009, 12:35
What the full model number?
e.g. WD400BB-00CPF0
PostPosted: May 18th, 2009, 12:40
Could be problem with PCB or pre amps are burned need more details to determine. Maybe picture of pcb will help too
Iorana Haraharaini
 Post subject: Re: Internal Barracuda hard disk stopped working
PostPosted: May 18th, 2009, 13:02
I appologise I was fed the wrong information by my Son.
The drive is as follows;
Barracuda 7200.7
160Gb
Model ST3160023A
S/N 3J836ZFN
P/N 9W2084-314
HDA P/N 100 275 532
Config D5G-02
If you require any more info let me know.
Elfie-gow
PostPosted: May 18th, 2009, 13:09
Check for any burned microchips on a board.
Most likely your square motor controler chip is toasted-SH6950D
www.datarecoveryne.com
PostPosted: May 18th, 2009, 13:39
Can i buy another board or retrieve my data somehow :?:
PostPosted: May 18th, 2009, 13:52
It would help if you posted a hi-res pic or scan of the component side of the PCB.
PostPosted: May 18th, 2009, 14:48
A picture of the Barracuda PCB is attached
Elfie-gow
File comment: PCB
PostPosted: May 18th, 2009, 16:46
Thats a great pic. Thanks!
I can't see any obvious problem from the pcb component side.
PostPosted: May 18th, 2009, 17:33
I had a very close look at the PCB and could not see any signs of damage.
What if anything can i try to get the disk working or the data back ?
Elfie
PostPosted: May 18th, 2009, 18:53
This is hard.
You need the proper knowledge for diagnose the pcb and repair it.
Or a good tool to read out the internal ROM and write it back to another known good and matching pcb.
Without these, i suggest to find a pro near you.
If the preamp is not burned, the cost will be low.
(For me about 100-150 EUR.)
Regards,
Janos
results-the-yourself-solutions-t11912.html
Users browsing this forum: No registered users and 93 guests
