 Post subject: Seagate Grenade model ST1000DM003
PostPosted: October 13th, 2014, 9:29
Hello
I'm working with a Seagate Grenade model ST1000DM003.
Initial problem: head bad, hdd clicking
I find a compatible donor, and I did swap head...
When power on disk, it can read servo marks (doesn't clickin, has sounds how a new HDD), but doesn't read ID... stay Busy all the time.
On terminal, didn't send F3, nothing works/answer, Ctrl Z X L ... nothing...
I tried did the short, but I haven't success.
The HDD continue doing the read of servo marks.
The PCB is 100%, I tested in others disks.
======Terminal log:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0019[0x0000636F][0x0000636F]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
RECOV Servo Op=0155 Resp=0005S
RECOV Servo Op=0055 Resp=0005xxxxZWZWZWZWZWZWZWZW
Thanks by any idea/tip...
Нет ничего невозможного
 Post subject: Re: Seagate Grenade model ST1000DM003
PostPosted: October 14th, 2014, 3:40
You need to short at a different time.
Users browsing this forum: Majestic-12 [Bot] and 96 guests
