 Post subject: But I saw it on the internet . . . .
PostPosted: July 21st, 2009, 0:21
I recently had a fellow bring by a 500 GB Seagate 7200.11 drive after he swapped heads at a local university's CLASS 10 clean ROOM (nope, I didn't leave off a zero!) They had an extra-clean environment for semiconductor fabrication & the like.
He did a reasonably good job considering - I was able to slowly image about 80% of the drive with the head set that he used. But the sad thing is that no head swap was required - the original problem was a blown TVS and overheated DC power strip. Much simpler fixes!
I asked him how he loaded and unloaded the heads on the drive, and he said, "carefully."
I asked him why he swapped heads and he said that he saw a video on the internet and it appeared fairly easy to do. I didn't ask him how he concluded that heads needed swapping when he also knew the PCB was toast.
Say what you will . . . lo ipse dixit.
http://www.datasaversllc.com
 Post subject: Re: But I saw it on the internet . . . .
PostPosted: July 21st, 2009, 16:08
I've never seen a video posted about doing a head swap.
PostPosted: July 21st, 2009, 18:04
Yes search on youtube, and u got a lot of "learning video" thats the problem people dont understand the importance of a good diagnostic, even many people did platter swap like first solutions and u get the results :rip:
PostPosted: July 21st, 2009, 18:24
It is so simple to swap heads and platters and anything in HDDs. U can see on the videos...
What U cannot see is that the result is a readable and recoverable drive :)
Since it is not :P
PostPosted: July 22nd, 2009, 0:28
nice, a $0 repair ends up costing $$$
Zero Alpha: zeroalpha.com.au
PostPosted: July 22nd, 2009, 9:45
Since it is not :P
Pepe sir ,
Greetings ,Practice Makes a Man Perfect ,How Life BTW
PostPosted: July 24th, 2009, 14:57
Yet to see a video of a repair start to the end, with data recovered. Maybe there is, to busy daily, to sit on video sites to find out.
PostPosted: July 24th, 2009, 15:59
Just curious... With all the porn stuff seen on the internet why we don't have tons of porn stars? It's even easier and funnier than DR. Ah, now don't put the dick in the freezer if doesn't work...
Users browsing this forum: Google [Bot] and 98 guests
