 Post subject: 5V fan mod may have killed my disk
PostPosted: September 4th, 2009, 19:18
Several weeks ago, I fried my 750GB Samsung harddisk (SAMSUNG HD753LJ F1_3D Rev A) by using a power plug from a regular 80 mm fan which has been subject to the 5V mod:
I've applied the 5V (see [1]) mod on three of my 80mm fans where they are connected together in series. At the end of the last fan's power cable there is a molex connector (see [2]), and without thinking any further I plugged the molex connecter into the Samsung disk. When I switched the machine on, BIOS wouldn't detect the harddisk. So, I think what's happened is that the harddisk has gotten 12V where it should have gotten 5V, and 5V where it should have gotten 12V. :-(
Since that particular harddisk uses SATA power connector, I used a SATA-to-molex power converter (see [3]) between the fan molex and the SATA harddisk.
The question is whether replacing the PCB from a similar harddisk will recover my files? I am mostly concerned how important it is to find a PCB with exactly the same firmware.
The closest thread that is somewhat similar to my problem is this: samsung-hd753lj-power-surge-t11606.html
[1]: http://www.silentpcreview.com/article6-page1.html
[2]: http://www.efilliate.com/images/prod_images/P305a.jpg
[3]: http://www.aria.co.uk/static/images/pro ... TA-POW.jpg
 Post subject: Re: 5V fan mod may have killed my disk
PostPosted: September 5th, 2009, 9:56
Post a pic of your PCB.
PostPosted: September 6th, 2009, 11:39
Unfortunately, I can only provide images taken with my phonecam. If the image quality isn't satisfactory, let me know. Thanks for your time.
(Dang, since yesterday afternoon I tried posting this message and always got an SQL-error. Now that I'm attaching the images instead of using the IMG-code, it seems to accept my post now.)
PostPosted: September 6th, 2009, 15:53
Check the two TVS diodes (two black rectangular components next to each other top left of PCB) for continuity with a multimeter, these should NOT be short.
Also check the "000" component next to them, this SHOULD be short.
Good luck
PostPosted: September 7th, 2009, 8:51
I will do that and will let you know. Thanks! :-)
PostPosted: September 7th, 2009, 20:43
Hi again.
Everything appears to be the opposite of what you have suggested: The left TVS has a 7-8 ohm resistance and the right 0 ohm resistance. I consider them both as shorted. Also, the 000 component isn't shorted, maximum resistance according to the multimeter. What can I make out of this? Thanks.
PostPosted: September 7th, 2009, 22:40
If accurate then sounds like two blown TVS and a blown fuse.
PostPosted: September 8th, 2009, 2:30
If read correctly, then yes.
Ideal solution is to replace all 3 components.
Risky solution (at your risk) is to just remove the two shorted TVS's and short the fuse.
PostPosted: September 8th, 2009, 8:30
Check for OTHER problems beyond... or "va-va-vooma" DC-DC and PREAMP.... beware...
PostPosted: September 8th, 2009, 11:22
Better still, take to a pro.
PostPosted: September 9th, 2009, 17:10
Either the way, you wouldn't recommend "simply" replacing the PCB over replacing the components?
BlackST: Sorry, what is "va-va-vooma"? Are you referring to an opamp? >_<
PostPosted: September 10th, 2009, 6:05
Va-va-vooma ... ehm... like a car running away at light speed ... or when you hear "CRACK! POOOOF!" and see a little cloud of smoke...
PostPosted: February 17th, 2010, 8:15
Hi again.
I know it's an old post but I finally had the luck and time to fix the hard drive so for the sake of history (yup, Google will handle that :).
The fix was "simply" to find a harddisk with a matching PCB. My dead disk's print board's revision number is 5. Last autumm I bought a Samsung 750GB REV. A rev. 6 in a store but at that time I didn't know the print board's revision number also matters - rev 6 didn't bring my disk back to life. [1] Then a few days ago I got hold of a rev. 4-disk (also 750GB REV. A) and that one worked well with my dead disk - well it's no longer dead! :-)
I'm just wondering what REV. A means - obviously, it's neither the firmware or the PCB version as it is printed on all three harddisks. Oh well...
[1]: Rev 6 PCB also looks pretty different from Rev 4 and 5.
Users browsing this forum: huangmiaofang and 147 guests
