 Post subject: VERY Strange Seagate Behavior
PostPosted: October 17th, 2012, 10:06
Guys, am wondering if any of you got some similar case to this:
1TB Seagate, ID`s fine, and everything works perfect, BUT here is what happens with it:
1- The Moment you access the DATA after no more than 45sec. the drive spins down
2- If i power it ON and leave it IS OK, but once accessing the DATA the counter starts again no more than 45sec.
3- Changed the PCB with 4 , same results, no over heat no sound which is not normal
4- If i leave it for 1-2h and power it ON again, i can access the DATA and again counter starts <=45sec
I really bet if someone saw such behavior like this in this damn seagate.
any clues???
 Post subject: Re: VERY Strange Seagate Behavior
PostPosted: October 17th, 2012, 10:16
Yes, I saw this behaviour....
Closed the case yesterday without data. Momentus 5400.4 (Holiday family)
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 17th, 2012, 10:49
Momentus 1TB ??
i guess you have no idea about what ur talking about...
PostPosted: October 17th, 2012, 11:01
Terminal?
PostPosted: October 17th, 2012, 11:22
Agreed northwind :) that's where I would start, perhaps with debug messages enabled there too (assuming einstein9 can access the terminal mode on this specific drive!).
I've got an idea about a type of fault which would cause this behaviour - terminal output should help to confirm/deny the type of problem.
@einstein9:
What do you mean by "Changed the PCB with 4"? 4 what? 4 other drives? I don't understand what you are trying to say, which is different to just "Changed the PCB".
PostPosted: October 17th, 2012, 11:51
Hi Guys
About the 4 i mean, i tried 4 pcb`s with the same result
In terminal (which i forgot to mention it on my 1st. post) no problem @ alll sounds normal
ASCII Diag mode
F3 T>
Rst 0x20M
(P) SATA Reset
btw, i know that sometimes in terminal while accessing the data it reports some errors/problems
but in this case there is not even a chance of having one, the time is so short.
I did test it many times with my TIMER, no more than 45sec.
PostPosted: October 17th, 2012, 12:16
Hi, Maybe try access data at different start point?
PostPosted: October 17th, 2012, 12:20
PM sent.
PostPosted: October 17th, 2012, 12:22
Time Frame I counted:
Power on to ready = 5-7sec
Util Open = 3sec more or less
DE Task (no save) = 10-13sec
Conclusion is: about 20-25sec
heheh i have only 20sec. to work on
And tried that btw, with the same results, the hdd insists on the time really, no more than 45sec. in total
i did my math here
Am telling you, i did many seagate here but this is the 1st. Unique Case
and thnx for the reply again
PostPosted: October 17th, 2012, 12:23
@ SquaL
very good advise
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 17th, 2012, 12:38
Momentus 1TB ??
in my case it was 500GB, i didn't count the timer, but it was the same symptom, everything is fine, but after accessing few sec it stops, in terminal same info like yours. no error, exactly same
__________
THANK YOU
SHAHI
PostPosted: October 17th, 2012, 12:46
Edit HDD ID to enable additional diag messages in terminal, might get some more useful info.
Data Recovery Cape Town
PostPosted: October 17th, 2012, 13:32
Thnx Nick will go through this since now am trying what Vulcan told
both sounds interesting really
many thnx will update you soon
PostPosted: October 18th, 2012, 6:56
Have you tried?
Angel Data Recovery
PostPosted: October 20th, 2012, 3:01
Thank you all guys, really bad news
my damn client took his hdd back he don`t want to wait
even by offering him FREE Service he refused - i wanted to go more through this case
really bad luck
and thank you all for the replies.. :( :(
Users browsing this forum: No registered users and 82 guests
