 Post subject: Hitachi HDP725050GLA360
PostPosted: March 11th, 2010, 12:42
Hi guys!
I dropped my keys on the PCB of my running HDD by mistake so I guess it got shorted out. The drive started clicking about 4-5 seconds after the accident, so I shut down my PC immediately (could not shut down the OS properly because the applications froze). I know it's a long shot, but I got a new HDD and I'm trying to swap the boards. It's the same model, it has the same properties, same number of sectors, same board, etc.
Simply swapping the boards didn't work, but I'm guessing the firmwares are different (the old hdd was made in 2007 and the new in 2010). How can I check what firmware was used on the old drive? Also what else can I do to get the drive working?
Appreciate any help
 Post subject: Re: Hitachi HDP725050GLA360
PostPosted: March 11th, 2010, 14:39
This drive has pretty-much unique data programmed into the NVRAM on the PCB, so you have <1% chance of getting one that works straight off, without transferring the NVRAM.
Suggest you contact pepe in the forum.
PostPosted: March 11th, 2010, 16:40
Guys from Hungary is on this forum, contact them for help.
www.datarecoveryne.com
PostPosted: March 11th, 2010, 16:59
Will do! Thanks for the advice.
PostPosted: March 12th, 2010, 0:47
Contact pepe or NC they are on hungary too and they are very professionals guys
