 Post subject: MHDD - Remap Feature freezes
PostPosted: April 16th, 2010, 8:26
Working on a 2.5" drive with bad sectors.
Have ran MHDD 4.6 - Scan with Erase Delays ON
Now, when I go to run MHDD with SCAN and Remap ON,
its just stops / freezes after just 2mins of scanning.
What to do next?
 Post subject: Re: MHDD - Remap Feature freezes
PostPosted: April 16th, 2010, 8:31
The drive is beyond repair with MHDD. If erasing (zerofill) doe not solve, the drive is beyond repair with NORMAL END-USER ways.
PostPosted: April 16th, 2010, 16:41
BlackSt, I did not Zerofill it at all. But I did select "erase delays" - is that the same thing as zerofilling the drive?
Is there still hope?
PostPosted: April 16th, 2010, 16:47
No, completely different. If you don't mind LOOSING ANY DATA ON THE DRIVE give a try with zerofill (ERASE command) . [u][b]IT WILL IRREVERSIBLY ERASE ANY DATA ON DRIVE[/b][/u].
After that, turn off then on and rescan. If the problems are "gone", you can "still" use the drive.
Be careful about selecting the correct drive = not to zerofill your system drive :D
PostPosted: April 16th, 2010, 17:11
if doing this disconnect all other drives from system
PostPosted: April 16th, 2010, 20:24
Can MHDD's erase and remap commands be used on an IMAGED drive
or do you have to used the ORIGINAL drive?
