 Post subject: Swap platters tool
PostPosted: May 21st, 2010, 6:46
Hi to all.
I need a tool for make swap platter from a Motor Blocked Hdd to a good motor same type Hdd.
The problem is to do not loos allignament from Hdd !!!
This Hdd have some metal block part, between platters (have 4 platters).
Someone can tell me if HDRC tools can make that swap if the Hdd have that Block between platters ?
If with HDRC tools is not possible, someone can tell me if there is some other tools for make that ?
Thank you very mutch to all. Bye :D
 Post subject: Re: Swap platters tool
PostPosted: May 21st, 2010, 7:49
or SD tools.
data recovery service[/b]
PostPosted: May 21st, 2010, 7:57
Or make your own...
PostPosted: May 21st, 2010, 8:39
No, HDRC tools and SD tools are not good (or even functional) for drives with spacers
PostPosted: May 21st, 2010, 8:52
It was what I imagined. HDRC and SD tools, will not work with HDD have the disk spacer.
Does anyone know if there is any method or tool that can i use for HDD with diskspacer?
Thank you to all :(
PostPosted: May 21st, 2010, 9:07
SERT or HDDSYNC, or make own.
PostPosted: May 21st, 2010, 9:08
HDRC hardly works with drives that DON'T have spacers, for that matter
PostPosted: May 21st, 2010, 10:15
I would like to correct you. HDRC tool can easily move platters from one HDD to another. Whether the HDD will actually work again is something completely different. :D
PostPosted: May 21st, 2010, 10:52
Sorry to all, but at this point i do not understand nothing !!!! :?:
I only need to know if HDRC, can swap platters, without move allignament of it, from a Hdd with motor blocked and DISK SPACER to another Hdd of same model but with good motor.
The problem for that operation was only the DISK SPACER, and i do not understand if HDRC can do it if Hdd have disk spacer.
Please help me to understand it :shock:
Thank you
PostPosted: May 21st, 2010, 13:36
I do not wish to sound mean, but you should not even be considering moving platters if you are not aware of the options and solutions that are out there for doing so.
There is basically 3 options: SERT, HDDSync, or self designed tools.
All of these options are going to run you at least ~$5000USD, and you will need a ISO100 (minimum) clean room to be able to perform it.
All of these solutions require a lot of practice to execute safely. Even seasoned techs who have done many of these transplants don't enjoy it; because no matter how practiced you are at the procedures there is still many things that can go wrong.
Regards,
PostPosted: May 22nd, 2010, 5:34
Totally agree
PostPosted: May 22nd, 2010, 10:52
As BlackST and arvika mentioned. Try to get into the habit of finding or making your own solutions otherwise your going to be spending an awful lot of money and will always be one step behind on new media.
Also note Russwinters comments. Your jumping in at the deep end here when it comes to faults drives can sustain. Not a very nice problem to fix.
If this is a one-off a pro is far far cheaper than the equipment needed. If you going to be doing a lot of drives I'd get tooling!
Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: May 22nd, 2010, 20:31
any body know where to get this one? any feedback for it?
PostPosted: May 23rd, 2010, 4:59
It's HD HPE SP. SD don't sell it now, because it need corrections.
PostPosted: May 23rd, 2010, 7:31
do you have others tools recommend?
PostPosted: May 23rd, 2010, 13:02
I have this for sale, bought it a while ago and not dared use it on clients drives.
PostPosted: May 23rd, 2010, 17:50
hi,
thanks for feedback.
PostPosted: May 25th, 2010, 13:58
have SD HPE pro. Dont dare using on clients drives but as practice had maybe 60 percent sucess with 2.5s and 30-40 with 3.5 drives.
PostPosted: May 26th, 2010, 3:08
For all :
I contact SD, and they say me that now the SD HPE PRO is not ready to sell.
They must be correction on tools, but tell me the new release can be used with Disk Space Hdd.
For now we can only wait, when new release are ready.
Thank you to all, for comment. :wink:
PostPosted: May 26th, 2010, 5:10
forget those SD and HDRC things, they will not work for their very principle on many drives.
the drives they work with u do not need those tools :)
Users browsing this forum: No registered users and 157 guests
