 Post subject: Need WD2000JS Firmware
PostPosted: June 3rd, 2010, 12:59
Hey all,
Help would be greatly appreciated, this isn't for a customer case; just tinkering around so it isn't *Critical*.
Looking for WD2000JS-98MHB0 firmware
revision: 02.01C03
I need all the modules if possible. (including translator)
Regards,
 Post subject: Re: Need WD2000JS Firmware
PostPosted: June 3rd, 2010, 15:01
Nevermind all. I was able to locate a drive with matching firmware, and happy to say that my "experiment" was successful.
Needless to say I was able to repair the translator without the need for regeneration. (module 32, and G-List where unreadable)
Mostly a lucky case I would say, I am going to look into this more on this series and see if it is consistent.
PostPosted: June 3rd, 2010, 15:13
Although you "repaired" the translator by copying from another drive, it's still not the original translator so there will almost certainly be data shifting.
PostPosted: June 3rd, 2010, 16:59
I thought so to, but 100% of it is good, there was a bunch of data on it.
PostPosted: June 7th, 2010, 11:44
After more testing and checking, it looks like module 32 on these drives is not as unique as you would expect, and can be taken from a drive with matching firmware (even a different size in most cases)
This could be actually classified as a (2) module, or (b) whichever classification scheme is in use. (with 1, and a being considered unique to a drive)
Regards,
