 Post subject: har ddrive no longer detected in the bios
PostPosted: June 12th, 2010, 22:21
I have this hard 5000aaks-65yga0 and was sometimes detected in the bios but now it cant be seen in the bios but the bios say that there is a hrd drive in this sata slot
do I need to get a firmware for this drive or do something else ?
please advise
thanks
 Post subject: Re: har ddrive no longer detected in the bios
PostPosted: June 12th, 2010, 22:32
Module problem
PostPosted: June 12th, 2010, 22:52
I am new to fixing hard drives, can you please describe more what I should do ?
thanks
PostPosted: June 12th, 2010, 23:11
Buy tools and start learning how to use them. You need the correct tools to work in SA and the knowledge aquired to do this work. If not out source your drives and learn how to do this one.
Iorana Haraharaini
PostPosted: June 13th, 2010, 8:10
Every pro was "new" once....
Maybe on WD forum ....
PostPosted: June 13th, 2010, 15:45
WD forum and support are very poor, do you know where I can get a firmware for this drive ?
thanks
PostPosted: June 13th, 2010, 16:23
Listen CAREFULLY :
Assuming the problem is firmware related (have doubts about it, but can be) :
- You need specialized EQUIPMENT (HW+SW) to work with firmware that cost in the 10'000 $ range + support fee AND know what to do (NOBODY will guide you troughout the repair process).
- You want a firmware : firmware is stored partly on the microcomputer on the circuit board, but the most relevant part is RECORDED ON THE PLATTERS inside the disk. Moreover, in the microcomputer there are UNIQUE parameters stored (UNIQUE for YOUR drive). It is not an Ipod or a cell phone so you can "flash" firmware on it.
You need the specialized equipment above + the know how to deal with it.
- Finally, you can "update" or "send" at user level a firmware if the drive is responding : your drive is NOT doing it so forget it.
The truth : your drive can have firmware corruption, but also a physical problem (I think it is more probably this the cause of the failure).
Truth #2 : the "support" forums and 95% of internet stuff fall into the "blind leading the blind" category : end users with zero or limited knowledge or at last copy/paste from other sources, often unchecked. Enthusiasm and good will is not enough when you need a solution. Of course WD people won't disclose the proprietary info about drive internals. Neither are we going to do it.
There are things that can be done at end-user level, other "maybe" with increasing risk of destroying data, other definitely not.
What you need : proper diagnose and pro intervention, or forget about data and carry on. I know it hurts. Usually, a backup can avoid all this and everything is limited to a replacement of the failed HDD.
P.S. if you were here, for a fraction of the cost of new similar HDD - assuming there is only FW problem - I can fix the drive and make it work again like brand new BUT WITH ALL DATA INSIDE COMPLETELY AND DEFINITIVELY DESTROYED (if you want a complete recovery the cost is definitely higher).
PostPosted: June 13th, 2010, 16:31
hi,
i have this kind of firmware in stock if you have right tool.
data recovery service[/b]
PostPosted: June 13th, 2010, 16:45
thanks for all the offers, allow me to ask one question please
wd offered a firmware upgrade on their site for wdxxxxys models (YSUpgrade.zip) the install instruction was software from DOS only - is it possible to find something like that for my model or that wont work ?
PostPosted: June 13th, 2010, 23:54
Yes but it is completely useless in your case - problem is elsewhere + drive not responsive. Good luck.
PostPosted: June 14th, 2010, 3:16
Exactly so.... "UPGRADE" firmware, not "REPAIR".... It has to be working in the first place for an upgrade to be performed.
PostPosted: June 14th, 2010, 8:28
ok thanks alot guys
Users browsing this forum: Bing [Bot] and 70 guests
