Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: is my Maxtor 6V250F0 dead?
PostPosted: June 4th, 2010, 11:42
hi there all,
i am looking for some support with recovering my hdd (or data)
i have just downloaded mhdd32ver4.5.exe, and made a bootable floppy,
earlier I used an boot-able 1GB-USBstick, I will explain later why i decided to start all over again with a floppy
the command ID returned:
Maxtor 6V250F0 LBA:490,234,752
SN V501CPDG FW: VA111630 cache: 16384KB size= 239372MB
Init drive: [recal]
[color=#FF0000]RECAL FAIL
(i don't understand what it means)[/color]
the command EID returned:
Supports: LBA48 HPA AAM DLMC LBA MS16 DMA (UDMA6, MWDMA2)
SMART: Disabled SelfTest: Supported Errorlog: Supported
Security: High, OFF. size= 239372MB
the following specifications at the top of the screen are marked with a blue background
INDX, DRSC, DRDY, HPA
MHDD>scan displays only exclamation marks !!!!! and an rapidly increasing "! ABRT"
the scan end with a blue screen, telling me that there is not enough room available for the log file,
this is why i quit working with the bootable USB stick.
MHDD>SMART ATT (I have read these parameters are the most imported ones)
Reallocated Sectors Count 253/ 253/ 0 (val/ worst/ raw)
HDA temperature 37/ 253/ 42 (val/ worst/ raw)
Ultra ATA CRC Error Rate 199/ 199/ 0 (val/ worst/ raw)
can you already conclude something about the condition of my hdd,
what information must i supply for a better conclusion
what are my following steps to recover the data
thanks already
 Post subject: Re: is my Maxtor 6V250F0 dead?
PostPosted: June 4th, 2010, 12:04
Probably some damage to the SA of the drive which causes to block access to the data; quite easy to fix for a professional with the proper tools, but unfortunately not by yourself.
Dobre
Murphy was an optimist
PostPosted: June 4th, 2010, 12:20
Seems definitely SA problem.
PostPosted: June 4th, 2010, 12:27
Hi Guys, SA?
Note Model Correct, SN Correct -->>> DISK module probably OK.
Note LBA correct -->>> Plist OK, GList OK (probably)
Reads Smart -->> Smart Ok? probably key mods correct.
FW Version == VA111630 -->> Mode OK.
Translator? - mostly linked to a faulty PList - probably NOT!.
Scan !!!!!!!!!!!!! ABRT - I would diagnose - most likely one head faulty :)
Diagnostics - the key to making the correct solution path.
PostPosted: June 4th, 2010, 12:47
pinkST wrote:
Hi Guys, SA?
You are wrong. Most recent case i had from Sabre that gave ABRT error was from bad GLIST.
btw, GLIST is part of SA, and also part of TRANSLATOR. And if PLIST has bad module header or checksum, I am pretty sure will give same symptoms too.
Again, is very likely SA fault, almost certainly repairable by a professional.
PostPosted: June 4th, 2010, 12:49
Assuming diagnostic is correct...
PostPosted: June 4th, 2010, 12:51
If one head was faulty, it would click furiously or not init and work like that.
PLIST/TRANSLATOR : model = 6V250F0. Does it say something ? It's not Calypso :D
Know how - the key to makE things work.
PostPosted: June 4th, 2010, 17:16
I suggest you take some VA11163 drives and muck up the G-List.
When you have done this report here what you find.
Be honest now :mrgreen:
PostPosted: June 5th, 2010, 6:36
Again, you most probably don't know how VAxxxx and FAMILY work. If you want info, this is the wrongest way.
PostPosted: June 6th, 2010, 5:56
BlackST,
Read here : translator-for-sabre2-t7448.html
That fella coffeebean :mrgreen:- he's quite smart even when Dobre was still asking questions.
Now, do as I say : modify 23 or 2C and report here. C'mon - Just do it !!
btw. Did you notice how "pro" was looking for button to press - (translator) ha, ha, ha, that was funny. :mrgreen:
PostPosted: June 6th, 2010, 6:11
Hi hddguy,
Induction - you should study the full meaning of this word.
It will help you enormously with statistics and learning how to do diagnostics
more successfully.
Induction - the trap for many amateurs - in all spheres of life.
PostPosted: June 6th, 2010, 7:20
What happened saturday night? :mrgreen:
PostPosted: June 6th, 2010, 8:17
we have to wait for next Friday :mrgreen:
ZeBong
" Россия еще раз"
PostPosted: June 6th, 2010, 10:27
C'mon BlackST, hddguy, Dobre :mrgreen: :mrgreen: :mrgreen:
Do as I say, read mods 23 or 2c on a SABRE and report here what you find.
Why you all so shy now?
Don't you want to answer the OP. He did ask the question politely.
zebong :mrgreen: I remember you when you first arrived at ace :lol:
to foolus is nOtsOEAsy (remember him?) :mrgreen:
PostPosted: June 6th, 2010, 10:36
Great , when you say remenber me at ACE did i meet you in Russia :) or in other country ;)
ZeBong
" Россия еще раз"
PostPosted: June 6th, 2010, 10:40
You will just have to wait until Friday. :( :mrgreen:
PostPosted: June 6th, 2010, 11:09
Pink, why then don't you suggest the OP what to do ? Without tools, of course :D ( if the OP had access to an UDMA, why get here ? ) . It's your turn now.
PostPosted: June 6th, 2010, 12:59
Yelo ta ya all :mrgreen: long time no write.
Is BlackST up to his nonsense again?
Why don't you answer the question BlackST.
PostPosted: June 6th, 2010, 13:02
Hi coffeebean :mrgreen: Yelo 2u2.
This BlackST I think he's too scared to answer the question.
C'mon BlackST answer the question.
Users browsing this forum: No registered users and 70 guests
