 Post subject: BAD SA
PostPosted: July 12th, 2010, 16:45
Hi to all!
Model WD2502ABYS
bads modules.
No acess data.
Нет ничего невозможного
 Post subject: Re: BAD SA
PostPosted: July 12th, 2010, 20:04
Fix the modules. Access the data.
http://www.datasaversllc.com
PostPosted: July 13th, 2010, 6:13
lol :)
sempre wrote:
Hi to all!
Model WD2502ABYS
bads modules.
No acess data.
As Mr.Jono said : fix the modules and access the data.
What's the problem then Mr.Sempre ?
PostPosted: July 14th, 2010, 8:24
unknown20010 wrote:
lol :)
sempre wrote:
Hi to all!
Model WD2502ABYS
bads modules.
No acess data.
My problem is SA not having experience of WD. these modules a question where can I find them to write them. Or still have some function that I can access the data without having to take these modules equal to write them? how to restore the translator?
MDL: WD250ABYS-23B7A0
DCM: HGRNHV2AAN
DOM: 09 AUG 2008
Thanks!!
PostPosted: July 14th, 2010, 9:28
What tool(s) do you have? PC3K or SD?
PostPosted: July 14th, 2010, 9:29
Looks like a pc3k report
PostPosted: July 14th, 2010, 9:35
Tool PC3K :mrgreen:
PostPosted: July 14th, 2010, 17:37
sempre wrote:
unknown20010 wrote:
lol :)
sempre wrote:
Hi to all!
Model WD2502ABYS
bads modules.
No acess data.
DCM: HGRNHV2AAN
DOM: 09 AUG 2008
Thanks!!
IS MDL: WD250ABYS-18B7A0
DCM:HARNHT2AAN
is modules compatibles?
PostPosted: July 14th, 2010, 21:28
does PCB is original??
data recovery service[/b]
PostPosted: July 14th, 2010, 22:08
I think the first step is to locate a suitable donor drive, or get a set of modules that match the firmware version. This is the hardest step, since there are multiple FW versions among the same WD drive models.
PostPosted: July 15th, 2010, 6:31
My client says yes, but I have my doubts! :(
PostPosted: July 15th, 2010, 6:33
please can you tell me what donor would be ideal or near ideal? :?:
PM
Thanks all!
PostPosted: July 15th, 2010, 8:10
HDD POSSIBLE DONOR
Techno mode key
Techno mode key......................... : Ok
RAM:
Zone allocation table................... : Ok
Cyl Count............................... : 170
SA SPT.................................. : 1311
Head number reading..................... : Ok
Heads number............................ : 2
ROM:
Flash Dir reading....................... : Ok
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.8TC
ROM generation.......................... : 05.91C
Link table version...................... : 04.AH.
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
ROM Firmware version.................... : 0005008T
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
SA Firmware version..................... : 00050091
HDD BAD
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error - Device Error Detected: "SERVO ERROR CODE BASE SvirADChang"
ROM:
ROM version............................. : 05.54B
ROM generation.......................... : 05.54B
Link table version...................... : 04.47.
ROM Firmware version.................... : 00050054
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Configuration reading................... : Module 02 not found
SA Firmware version..................... : Module part reading error - Device Error Detected: "Unknown error. Error code: 0101"
PCB HDD BAD IN HDD DONOR
Techno mode key
RAM:
ROM:
Service area:
SA structure test
FAIL PCB HDD BAD? AND OR NOT ORIGINAL PCB? THERE IS THE POSSIBILITY THAT WITH THOSE SELLING LOGS?
PostPosted: July 15th, 2010, 8:33
This post is fast becoming confusing.
First screenshot shows SA structures, but recent post shows no SA available? Why do you think you need donor, what do you plan to do?
This should be a pretty simple recovery with right tools. Some overlays damaged, some other modules may need repair, or HotSwap may allow access to data if done correct.
I can not understand exactly what you are asking here?
Users browsing this forum: No registered users and 82 guests
