 Post subject: help identify Maxtor TVS 6L200M0
PostPosted: November 8th, 2008, 18:04
Drive does not spin up.
Zero resistance across this component (Upper left, circled in red). The drive spins up OK with a different Maxtor (PATA) board attached but the boards are not compatible.
I assume with a fair amount of certainty that this is the TVS and the problem, but it is probably better to ask ;)
http://www.youtube.com/user/TerraformingMaster
 Post subject: Re: help identify Maxtor TVS 6L200M0
PostPosted: November 8th, 2008, 18:47
hello,
check PM
data recovery service[/b]
PostPosted: November 8th, 2008, 20:15
Those model often suffer from failed Motor controler L7250 1.2
www.datarecoveryne.com
PostPosted: November 10th, 2008, 11:05
Do you have the use of a multimeter?
PostPosted: September 21st, 2010, 1:08
Yes.
And after all this time, the drive is still sitting on a shelf here gathering dust, strangely enough. I guess I had forgotten it.
PostPosted: September 21st, 2010, 4:05
This model have no TVS.
PostPosted: September 21st, 2010, 5:00
Your photo is not very clear, but if the following PCB is similar, then there is a 12V TVS diode marked "BUX" in the top LH corner, exactly where you have circled it:
http://www.besthddparts.com/us/pic/040118900-1.JPG
If there is no other damage, the drive will work without the diode, but there will no longer be any overvoltage protection on the +12V supply. Be sure your PSU is OK.
If, for continued protection, you wish to replace the diode, you can obtain an SMBJ12A from Farnell, Mouser, Digikey.
Good luck.
PostPosted: September 21st, 2010, 12:10
Fzabkar is right, this is sata board, and i have not seen the picture. :)
Anyway, never seen any TVS issue on this model before, all have burned the power fet and/or the VCD, and sometimes the MCU too.
Janos
PostPosted: September 21st, 2010, 12:24
And FUBAR preamp too... "zzzinng.... zzziiinng..." at power on ....
PostPosted: September 21st, 2010, 12:44
N.C. wrote:
Anyway, never seen any TVS issue on this model before ...
A TVS fails due to external reasons, eg an overvoltage as a consequence of a PSU failure or user error. Therefore your comment makes no sense.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 51 guests
