 Post subject: maxtor 160gb 30% unreadable need help to retrieve data
PostPosted: February 4th, 2011, 14:30
Please help my 160gb maxtor drive has failed and in windows CHKDSK about 30% of sectors show as unreadable the disk contains all the family photo's so the data is valuable....
i have run diagnostic software and they either fail or it says it would take 1000's of hrs to complete repair cycle
also drive reports temp of over 80 deg c even when cold
so i think my best option is to copy everything to a new drive which i have and then try the repair
can someone recomend software that would copy as best it could the whole drive to another without stopping on errors
i need to get it right first time as i am thinking of freezing the drive
i have looked on google and cant find anything that fits my needs...!
so i thought i would ask the experts (thats you :D )
Thanks in advance for any replies
Rob Morby
(MorbiouS)
which one of my personality do you want to talk too
 Post subject: Re: maxtor 160gb 30% unreadable need help to retrieve data
PostPosted: February 4th, 2011, 15:29
DON'T freeze the drive! Please.
You can try ddrescue in Linux to mirror your drive. But, if your data is valuable to you at all, send it to pcimage for a diagnostic first. If his price is too high, then continue to try your own things. If you use data recovery as a last option, you will most certainly find that you will be paying a lot more for to get your data back.
PostPosted: February 4th, 2011, 16:11
Should be not too expensive right now, if you don't tamper with it any more.
If you kill the drive completely expect a cost of 10x what it would be now, these are hideous drives IMHO.
As Luke says DO NOT FREEZE IT.
Users browsing this forum: Google [Bot] and 56 guests
