 Post subject: WD10EADS 1TB Motor stuck
PostPosted: February 18th, 2011, 12:00
I have a WD10EADS 1TB HDD that I am trying to repair for a customer. The drive fell and my pre diagnostics revealed that the motor seems to be stuck and not spinning. I attempted to turn the spindle myself but it really seems to be stuck. Does WD have a locking technology for this drive that may have been enabled? Can it be unlocked? Or should I change the Motor?
Thank you for any advise.
DataSafe Limited
Trinidad.
 Post subject: Re: WD10EADS 1TB Motor stuck
PostPosted: February 18th, 2011, 12:05
If you cannot free the motor up, you will need to do a platter swap. If you do not know how to do these correctly then do not try.
PostPosted: February 18th, 2011, 20:08
forcing the spindle to rotate will create wobble. Heads can ram the platter if the wobble is to big causing mucho damage. If the wobble is not to much - heads can still have problems catching on servo. IMO u need to swap the platters but like Cleanroom said - if u never did it dont. To many ways to screw up.
PostPosted: February 18th, 2011, 20:28
It would be best to outsource this case.
Users browsing this forum: No registered users and 61 guests
