 Post subject: WD6400AAKS-75A7B0 no spinup but odd soft clicking sounds
PostPosted: February 28th, 2011, 14:03
I really hope someone can help me with my hdd failure. It was sudden and without warning.
This 640GB is a WD6400AAKS-75A7B0 DCM:HANNHV2MA, it was installed in a USB enclosure.
Have tried different power source, but still:
- not detectable in BIOS
- no spinup
- very soft clicking sounds heard (odd to hear clicks when hdd is not spinning)
I also measured with a meter and found no short between 5V & Gnd or 12V & Gnd.
Appreciate any help or advice from gurus here.
 Post subject: Re: WD6400AAKS-75A7B0 no spinup but odd soft clicking sounds
PostPosted: March 1st, 2011, 9:50
I recorded the clicking sound, it is very soft, have to put my ears right above the hdd to hear it.
Please guys can you have a listen and tell me what you think:
http://www.toofiles.com/en/download/doc ... licks.html
Should I be looking for a board to swap? Or is there any other tests I can do to narrow it down?
PostPosted: March 1st, 2011, 12:25
It does sound like clicks a bit. In this event ur initial assessment of the drive not spining is incorrect. If the drive will not spin - the heads will not move. So if the drive clicks and spins - then there is a little whiny sound there that is kinds scary... Sounds like the slider is skimming the surface of the platter. All in all make another recording , as hiqh quality as u can preferably a video of you turning it on.
It does not sound good atm...
PostPosted: March 1st, 2011, 20:20
http://www.toofiles.com/en/download/doc ... icks2.html
This is another higher bit recording with volume nomalised to make it louder but sorry I just can't remove the background electrical noise.
I believe it is not spinning because if I hold it in hand and power on, there is zero vibration and no feeling of the usual torque when motor starts. That's why I find it very odd. Hopefully you guys can shed more light onto it. Thanks for responding.
PostPosted: March 2nd, 2011, 4:43
Maybe spindle seizure or head stuck to the platter.
data recovery Poland
PostPosted: March 2nd, 2011, 11:30
Mike this is a good enough recording , however it sounds to me like a standard clicking drive. Platters will spin in that situation. Cant really help more without holding the drive.
PostPosted: April 28th, 2011, 12:04
I can't believe it I got my hdd working! Saved all my files!
It was a youtube video that helped - did a few gentle frisbee-like twists, power-on, and it spin right up.
Hope this helps anyone in similar situation.
Users browsing this forum: Google [Bot] and 54 guests
